Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > Product Announcements & Manufacturer News
Product Announcements & Manufacturer News If you are a manufacturer or company with relevant news related to machining or have a new product announcement you may post it here only! (Commercial Posting Forum)
Old 08-05-2009, 10:29 AM
wardcomm is on a distinguished road
IBAG Adjustable Right Angle HS Spindles
IBAG North America has introduced a new adjustable right angle high speed spindle to its “Micro Line” for Swiss machining applications. Ideal for high speed slot milling and cross drilling, the new 25 mm diameter spindle is adjustable from +/- 30 degrees, features spindle speed range to 80,000 RPM, infinitely variable, with oil mist lubrication. The spindle mount adapter is available for 25, 22, 20 19.05 mm mounting diameters. This new right angle spindle utilizes synchronous, DC motor technology and delivers 109 watts peak power, 84 watts continuously duty spindle power. “Micro Line” spindles feature high rigidity and ultra precision (less than 2 microns run-out) for dramatically enhanced surface quality and high machining accuracy required for complex and stringent micro-machining demands.
Contact: Rick Testani
Tel. 203-407-0397
e-mail: RickT@ibagna.com
www.ibagnorthamerica.com
Old 08-05-2009, 10:36 AM
Old 08-05-2009, 10:38 AM
http://i907.photobucket.com/albums/ac271/wardcomm1/RASpinde.jpg[/IMG][/IMG]
Old 08-05-2009, 10:46 AM
[/IMG]
shoptask adjustable feet leeharrysouth Shopmaster/Shoptask 3 02-22-2009 08:54 AM
Problem- Adjustable boring bar Arcticfox46 CNC Tooling 5 01-05-2009 07:11 PM
Problem- Adjustable Boring bar Arcticfox46 General Metalwork Discussion 1 01-05-2009 03:43 PM
Adjustable Support Blocks ninthmp Linear and Rotary Motion 2 05-10-2007 04:59 AM
