Jet Edge, Inc., a leading manufacturer of ultra-high pressure
waterjets, is pleased to introduce its new economical iP60-100S 100hp 60,000 psi (4,100 bar)
waterjet pump.
Priced at just $62,500* U.S., the iP60-100S is the most affordable 100hp 60,000psi waterjet intensifier pump on the market. The iP60-100S is a single intensifier version of Jet Edge’s popular 100hp waterjet pump. By eliminating the second intensifier, Jet Edge is able to offer the iP60-100S at a low price without sacrificing quality. The iP60-100S waterjet intensifier pump produces 2.0 gpm (7.6 lpm) of ultra-high pressure water for precision
waterjet cutting, water blasting, cleaning and surface preparation applications. It supports orifices up to .021” (.53 mm).
Like all Jet Edge waterjet pumps, the iP60-100S features Jet Edge’s reliable tie-rod design. This design has no threaded cylinder, no threaded end caps, and no threaded hydraulic cylinder, making it less prone to cracking than threaded designs. Matched-metal components prevent galling of hydraulic system components. Jet Edge water jet pumps feature hydraulic accumulators, which reduce wear on the hydraulic pump. Hydraulic fluid also is cooled and filtered. Jet Edge waterjet pumps feature a rugged hydraulic center section which incorporates high-duty cycle-rated piston seal and wear rings; free-floating self-aligning plungers increase seal life. Jet Edge’s hydraulic systems have a 4,000-hour warranty. Jet Edge water jet pumps also feature attenuators which smooth pressure fluctuations and deliver a constant and steady stream of ultra-high pressure water to the cutting tool, ensuring optimal cut quality. Jet Edge offers a wide range of electric and diesel waterjet intensifier pumps from 30-280hp; 36,000, 60,000 and 90,000 psi models are available.
iP60-100S Waterjet Pump Specifications About Jet Edge
Established in 1984, Jet Edge is a global designer and manufacturer of waterjet systems for precision cutting, surface preparation and coating removal. Jet Edge systems are used around the world in a broad range of industries, from the world's leading airlines to automotive, aerospace, industrial manufacturers, machine and job shops. Jet Edge waterjet systems are proudly made in the U.S.A.
More Information
For information about Jet Edge, visit
www.jetedge.com, e-mail
sales@jetedge.com or call 1-800-JET-EDGE (538-3343).
Information Request Form
* Price excludes starter package, plumbing, spares, tools, installation, excise taxes, sales taxes, use taxes, transportation taxes, any other types or forms of taxes. Jet Edge sales terms are FOB Factory and price is in US Dollars.
