| Product Announcements & Manufacturer News If you are a manufacturer or company with relevant news related to machining or have a new product announcement you may post it here only! (Commercial Posting Forum) |
| paint sprayer, airless sprayer, painting machine, spray painting, airless paint sprayer, electric sprayer, pneumatic sprayer, spraying machine, spray paint, high-pressure airless sprayer, spray gun, paint spraying Series NK-WP is air-driven type airless paint sprayer adopting mechanism-direction-change. It is a high pressure-ratio airless sprayer with widely application. Applied to shipbuilding, steel structure, wall painting, bridges maintenance, oil pipeline of thick-film high-viscosity paints, anti-corrosion paints. The Paints include: coal tar pitch epoxy resin paints, thick-paste type epoxy resin paints, High solid epoxy paints, super-oxide paints and so on. Feature: 1. High pressure-ratio, widely application, large output, High reliability, low noise, safety. 2. Special Seals imported from Germany. Piston with special enhanced treatment, making sure high hardness, anti-corrosion, super wear-resistant. 3. This airless paint sprayer can spray all kinds of conventional paints, thick-film high viscosity paints to meet the different requirements of anti-corrosion. 4. Adopts mechanism-direction-change, reliable, avoiding airless sprayer “dead”. 5. Adopts “Single-shaft Separated-body of Dual booster pump”, the air-motor and plunger pump are connected separately, avoiding high pressure paints escape into air-motor. 6. Adopts new technology of “low-temperature cylinder-lubrication”, Making sure the airless sprayer has a good performance under low temperature situation, avoiding "ice blocking. Technical Parameters: Model: NKWP73 Pressure Ratio: 73 :1 No-Loading Max output: 21 L/min Inlet air-pressure: 0.3~0.7 MPa (3 ~ 7 Bar) Max Air-Displacement: 51 MPa (510 Bar) Air Consumption: 300 ~ 1800 L/min Packing Dimension (L*W*H): 700mm*660mm*1290mm N.W /G.W: 82Kgs / 105Kgs Products list: 1 NK-EAseries:Electric-driven high-pressure airless sprayer, operation simply, working without air compressor. The paints includes: wall paint, water-based paints, oil paints and anti-corrosion paints with low and medium viscosity. 1.1 NK-EA20: Max output: 1.8 ~2.0 L/min 1.2 NK-EA22:Max output: 2.0 ~2.2 L/min 1.3 NK-EA24: Max output: 2.2 ~2.4 L/min 1.4 NK-EA26: Max output: 2.4 ~2.6 L/min 2 NK-WJ series: air-driven type airless paint sprayer adopting air-direction-change. Applied to think-film high-viscosity paints, anti-corrosion paints. The paints include: PVC paints,Thick-Paste Epoxy paints, Super-Epoxy paints, Epoxy-Zinc-Rich Paints, Inorganic Zinc Paints. 2.1 NK-WJ32: Pressure Ratio: 32 : 1 No-Loading Max output: 56 L/min 2.2 NK-WJ46: Pressure Ratio: 46 : 1 No-Loading Max output: 40 L/min 2.3 NK-WJ65: Pressure Ratio: 65 : 1 No-Loading Max output: 25 L/min 2.4 NK-WJ56: Pressure Ratio: 56 : 1 No-Loading Max output: 29 L/min 3 NK-WP series: Air-driven type airless paint sprayer adopting mechanism-direction-change. Applied to think-film high-viscosity paints, anti-corrosion paints. 3.1 The Paints include: coal tar pitch epoxy resin paints, thick-paste type epoxy resin paints, High solid epoxy paints, super-oxide paints and so on. 3.1.1 NK-WP73: Pressure Ratio: 65 :1 No-Loading Max output: 21 L/min 3.1.2 NK-WP65A: Pressure Ratio: 65 :1 No-Loading Max output: 28 L/min 3.2 The Paints include: thick-paste type epoxy resin paints, Asphalt Modified Epoxy paints, super-oxide paints and so on. 3.2.1 NK-WP65C: Pressure Ratio: 65 :1 No-Loading Max output: 25 L/min 3..2.2 NK-WP63C: Pressure Ratio: 63 :1 No-Loading Max output: 28 L/min 3.3 The paints include: PVC paints, Thick-Paste Epoxy paints, Super-Epoxy paints, Epoxy-Zinc-Rich Paints 3..3.1 NK-WP45B: Pressure Ratio: 45:1 No-Loading Max output: 32 L/min 3.4The Paints include: Chlorinated Rubber, Phenolic, Amino, nitro, acrylic, architectural latex paints. 3.4.1 NK-WP32A: Pressure Ratio: 32:1 No-Loading Max output: 8 L/min 4 Spare parts for NOKE airless sprayer 4.1 spraying guns 4.2 spraying pole 4.3 spraying nozzle 4.4 high Pressure Hose 4.5 other Accessories such as: Seal, Filter Contact name: Anna e-mail: annaw127@hotmail.com / anna84223@yahoo.com MSN: annaw127@hotmail.com skype: annaw127 yahoo messenger: anna84223@yahoo.com Gmail (google talk) : annaw127@gmail.com Website: bestsprayer.diytrade.com Phone: 86-23-68163118 Fax: 86-23-68163118 Your inquiries are highly welcome at any time, we are ready to make a response very soon |
| Tags |
| airless sprayer, paint sprayer, spray gun |
| NK-WJ46 airless paint sprayer with air-driven type | paintsprayer | Product Announcements & Manufacturer News | 0 | 08-03-2009 10:32 PM |
| NK-EA22 airless paint sprayer with electric-driven high-pressure | paintsprayer | Product Announcements & Manufacturer News | 0 | 08-03-2009 10:24 PM |
| 20 ton die cast sprayer | Apresto | Mechanical Calculations/Engineering Design | 0 | 08-03-2009 12:28 PM |
| long chang machinery mill | chris_boyce | General Metal Working Machines | 7 | 07-28-2008 07:27 PM |
| mold release sprayer | smarbaga | Mechanical Calculations/Engineering Design | 5 | 02-01-2006 07:46 PM |
