Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > Product Announcements & Manufacturer News
Product Announcements & Manufacturer News If you are a manufacturer or company with relevant news related to machining or have a new product announcement you may post it here only! (Commercial Posting Forum)
Old 08-03-2009, 10:32 PM
paintsprayer is on a distinguished road
Smile NK-WJ46 airless paint sprayer with air-driven type
Series NK-WJ is air-driven type airless paint sprayer adopting air-direction-change. Applied to shipbuilding, steel structure, wall painting, bridges maintenance,oil pipline of thick-film high-viscosity paints, anti-corrosion paints. The paints include: PVC paints,Thick-Paste Epoxy paints, Super-Epoxy paints, Epoxy-Zinc-Rich Paints, Inorganic Zinc Paints.
Features:
1. Equips the latest air-motor, large output, small pulsation, long lifetime.
2. Special Seals imported from Germany. Piston with special enhanced treatment, making sure high hardness, corrosion-resistant, super wear-resistant, long lifetime.
3. This airless paint sprayer can spray all kinds of conventional paints, thick-film high viscosity paints to meet the different requirements of anti-corrosion.
4. With a vertical, wall-mounted, portable, car-style, to meet the personalized needs of customers.
5. Effective spraying, no bubbles, no impurities, painting uniformity.
Technical Parameters:
Model: NKWJ46
Pressure Ratio: 46 : 1
No-Loading Max output: 40 L/min
Inlet air-pressure: 0.3~0.6 MPa (3 ~ 6 Bar)
Air Consumption: 500 ~ 1200 L/min
Packing Dimension (L*W*H): 570mm*450mm*900mm
N.W /G.W: 58Kgs / 80Kgs
Products list:
1 NK-EAseries:Electric-driven high-pressure airless sprayer, operation simply, working without air compressor. The paints includes: wall paint, water-based paints, oil paints and anti-corrosion paints with low and medium viscosity.
1.1 NK-EA20: Max output: 1.8 ~2.0 L/min
1.2 NK-EA22:Max output: 2.0 ~2.2 L/min
1.3 NK-EA24: Max output: 2.2 ~2.4 L/min
1.4 NK-EA26: Max output: 2.4 ~2.6 L/min
2 NK-WJ series: air-driven type airless paint sprayer adopting air-direction-change. Applied to think-film high-viscosity paints, anti-corrosion paints. The paints include: PVC paints,Thick-Paste Epoxy paints, Super-Epoxy paints, Epoxy-Zinc-Rich Paints, Inorganic Zinc Paints.
2.1 NK-WJ32: Pressure Ratio: 32 : 1
No-Loading Max output: 56 L/min
2.2 NK-WJ46: Pressure Ratio: 46 : 1
2.3 NK-WJ65: Pressure Ratio: 65 : 1
No-Loading Max output: 25 L/min
2.4 NK-WJ56: Pressure Ratio: 56 : 1
No-Loading Max output: 29 L/min
3 NK-WP series: Air-driven type airless paint sprayer adopting mechanism-direction-change. Applied to think-film high-viscosity paints, anti-corrosion paints.
3.1 The Paints include: coal tar pitch epoxy resin paints, thick-paste type epoxy resin paints, High solid epoxy paints, super-oxide paints and so on.
3.1.1 NK-WP73: Pressure Ratio: 65 :1
No-Loading Max output: 21 L/min
3.1.2 NK-WP65A: Pressure Ratio: 65 :1
No-Loading Max output: 28 L/min
3.2 The Paints include: thick-paste type epoxy resin paints, Asphalt Modified Epoxy paints, super-oxide paints and so on.
3.2.1 NK-WP65C: Pressure Ratio: 65 :1
3..2.2 NK-WP63C: Pressure Ratio: 63 :1
3.3 The paints include: PVC paints, Thick-Paste Epoxy paints, Super-Epoxy paints, Epoxy-Zinc-Rich Paints
3..3.1 NK-WP45B: Pressure Ratio: 45:1
No-Loading Max output: 32 L/min
3.4The Paints include: Chlorinated Rubber, Phenolic, Amino, nitro, acrylic, architectural latex paints.
3.4.1 NK-WP32A: Pressure Ratio: 32:1
No-Loading Max output: 8 L/min
4 Spare parts for NOKE airless sprayer
4.1 spraying guns
4.2 spraying pole
4.3 spraying nozzle
4.4 high Pressure Hose
4.5 other Accessories such as: Seal, Filter
Contact name: Anna
e-mail: annaw127@hotmail.com / anna84223@yahoo.com
MSN: annaw127@hotmail.com
skype: annaw127
yahoo messenger: anna84223@yahoo.com
Gmail (google talk) : annaw127@gmail.com
Website: bestsprayer.diytrade.com
Phone: 86-23-68163118
Fax: 86-23-68163118
Your inquiries are highly welcome at any time, we are ready to make a response very soon.
Tags
airless sprayer, paint sprayer, spray gun
NK-EA22 airless paint sprayer with electric-driven high-pressure paintsprayer Product Announcements & Manufacturer News 0 08-03-2009 10:24 PM
20 ton die cast sprayer Apresto Mechanical Calculations/Engineering Design 0 08-03-2009 12:28 PM
Does anyone here paint with cnc? slashmaster Hobby Discussion 3 03-08-2009 06:40 PM
what type of paint to use on milling machine or lathe derkiow General Metal Working Machines 2 03-08-2006 03:52 AM
mold release sprayer smarbaga Mechanical Calculations/Engineering Design 5 02-01-2006 07:46 PM
