| Product Announcements & Manufacturer News If you are a manufacturer or company with relevant news related to machining or have a new product announcement you may post it here only! (Commercial Posting Forum) |
| paint sprayer, airless sprayer, painting machine, spray painting, airless paint sprayer, electric sprayer, pneumatic sprayer, spraying machine, spray paint, high-pressure airless sprayer, spray gun, paint spraying Series NK-EA is the electric-driven high-pressure airless sprayer, operation simply, working without air compressor. Applied to painting of wall, steel constructure, workpiece, equipment, pipes and other small paint spraying project. The paints includes: wall paint, water-based paints, oil paints and anti-corrosion paints with low and medium viscosity. Features: 1. Small size, light weight, and easy to carry. 2. Adopts military brushless-DC electric motor, high quality, good performance. 3. Intelligent electronic control mode of computer chip, LCD displayer, monitoring electric motor online. 4. Special Seals imported from Germany. Piston with special enhanced treatment, making sure high hardness, corrosion-resistant, super wear-resistant, long life. 5. Small pulsation, top quality painting film, no bubbles, no impurities. 6. High spraying efficency, less pollution, low noise Technicla Parameters: Model: NKEA22 Max output: 2.0 ~2.2 L/min Max working pressure: 20 MPa (200 Bar) Electric motor power: 0.65 kW Power supply: 110V/220V, 50Hz (As per Customer’s requirements) Packing Dimension (L*W*H): 475mm**440mm*465mm Net weight /Gross Weight:: 20 Kgs / 26.5Kgs Products list: 1 NK-EAseries:Electric-driven high-pressure airless sprayer, operation simply, working without air compressor. The paints includes: wall paint, water-based paints, oil paints and anti-corrosion paints with low and medium viscosity. 1.1 NK-EA20: Max output: 1.8 ~2.0 L/min 1.2 NK-EA22:Max output: 2.0 ~2.2 L/min 1.3 NK-EA24: Max output: 2.2 ~2.4 L/min 1.4 NK-EA26: Max output: 2.4 ~2.6 L/min 2 NK-WJ series: air-driven type airless paint sprayer adopting air-direction-change. Applied to think-film high-viscosity paints, anti-corrosion paints. The paints include: PVC paints,Thick-Paste Epoxy paints, Super-Epoxy paints, Epoxy-Zinc-Rich Paints, Inorganic Zinc Paints. 2.1 NK-WJ32: Pressure Ratio: 32 : 1 No-Loading Max output: 56 L/min 2.2 NK-WJ46: Pressure Ratio: 46 : 1 No-Loading Max output: 40 L/min 2.3 NK-WJ65: Pressure Ratio: 65 : 1 No-Loading Max output: 25 L/min 2.4 NK-WJ56: Pressure Ratio: 56 : 1 No-Loading Max output: 29 L/min 3 NK-WP series: Air-driven type airless paint sprayer adopting mechanism-direction-change. Applied to think-film high-viscosity paints, anti-corrosion paints. 3.1 The Paints include: coal tar pitch epoxy resin paints, thick-paste type epoxy resin paints, High solid epoxy paints, super-oxide paints and so on. 3.1.1 NK-WP73: Pressure Ratio: 65 :1 No-Loading Max output: 21 L/min 3.1.2 NK-WP65A: Pressure Ratio: 65 :1 No-Loading Max output: 28 L/min 3.2 The Paints include: thick-paste type epoxy resin paints, Asphalt Modified Epoxy paints, super-oxide paints and so on. 3.2.1 NK-WP65C: Pressure Ratio: 65 :1 No-Loading Max output: 25 L/min 3..2.2 NK-WP63C: Pressure Ratio: 63 :1 No-Loading Max output: 28 L/min 3.3 The paints include: PVC paints, Thick-Paste Epoxy paints, Super-Epoxy paints, Epoxy-Zinc-Rich Paints 3..3.1 NK-WP45B: Pressure Ratio: 45:1 No-Loading Max output: 32 L/min 3.4The Paints include: Chlorinated Rubber, Phenolic, Amino, nitro, acrylic, architectural latex paints. 3.4.1 NK-WP32A: Pressure Ratio: 32:1 No-Loading Max output: 8 L/min 4 Spare parts for NOKE airless sprayer 4.1 spraying guns 4.2 spraying pole 4.3 spraying nozzle 4.4 high Pressure Hose 4.5 other Accessories such as: Seal, Filter Contact name: Anna e-mail: annaw127@hotmail.com / anna84223@yahoo.com MSN: annaw127@hotmail.com skype: annaw127 yahoo messenger: anna84223@yahoo.com Gmail (google talk) : annaw127@gmail.com Website: bestsprayer.diytrade.com Phone: 86-23-68163118 Fax: 86-23-68163118 Your inquiries are highly welcome at any time, we are ready to make a response very soon. |
| Tags |
| airless sprayer, paint sprayer, painting machine |
| Need Help!- How High can a motor be driven with VFD? | Adamj12b | General Electronics Discussion | 2 | 04-16-2009 10:29 AM |
| High pressure coolant systems | CHAD LAWSON | General Metalwork Discussion | 3 | 08-25-2008 04:15 PM |
| High Pitched Whine From VFD Driven Motor | hamholfarm | Phase Converters and VFD | 3 | 07-22-2008 05:55 PM |
| High pressure pump | LT1TRUCK | Deckel, Maho, Aciera, Abene Mills | 0 | 01-30-2008 02:16 PM |
| high-pressure coolant | 307startup | Mechanical Calculations/Engineering Design | 7 | 09-29-2007 04:40 PM |
