Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > Product Announcements & Manufacturer News
Product Announcements & Manufacturer News If you are a manufacturer or company with relevant news related to machining or have a new product announcement you may post it here only! (Commercial Posting Forum)
Old 06-19-2009, 02:40 PM
Pacific Bearing is on a distinguished road
Lightbulb Nuclear Reactor Re-fueling Supported by Hevi-Rail Bearings
For sustained linear motion on high load capacities, PBC Linear’s Hevi-Rail® heavy duty bearing system is second to none for long-lasting linear motion in the toughest of environments. This reputation was put to the test when Hevi-Rail® was designed into a rotating “lazy susan” system for nuclear reactor vessel stud racks by Quality Engineered Products. Supporting immense weight, the Hevi-Rail® bearings ensured a safer environment for the maintenance team and dramatically decreased prep time.
A nuclear reactor vessel generates a large amount of power, but periodically requires inspection and re-fueling. This necessary maintenance can only be performed while the reactor is powered down. Time is critical in this case, the longer the reactor is powered down, the less overall electricity produced. To re-fuel the reactor, a maintenance crew needs to unbolt the vessel by removing ALL 54 studs that secure the head. Each individual screw weighs upwards of 600-700 lb, and calls for an overhead crane to lift. Traditionally, these studs would be placed in square racks that constantly needed repositioning under the overhead crane for successful loading. This made the time required for unloading the studs to rise excessively and caused a potential risk factor for the maintenance crew. However, Quality Engineered Products designed a new type of stud rack using PBC Linear’s Hevi-Rail® machined into a “lazy susan” configuration.
Thanks to the ingenuity of Quality Engineered Products and the long-lasting heavy-duty performance of Hevi-Rail®, the maintenance crew no longer needed to waste time repositioning the stud rack under the crane in order to proceed with the loading process. The time saved is doubled as the entire process is performed in reverse during reactor re-assembly after refueling.
About 42’’ in diameter, the new circular stud rack could be hand-rotated to facilitate easy loading from the crane. Hevi-Rail® works to promote an even dispersion of loads and forces being acted upon it. Machined into a circular rail, the hardened steel rail and bearings had no problem tolerating the total weight of 9 reactor studs! The Hevi-Rail® bearing’s innovative linear and axial bearings also allowed for a smooth rotating motion that immediately pleased the maintenance crew due to the new-found ease in their job.
To find out more on the RSV Stud Rack or other custom products, please visit Quality Engineered Products Inc. at qualengpro.com.
For more information on Hevi-Rail® or any other PBC Linear products please call 1.800.729.9085, email to marketing@pacific-bearing.com, or visit us at our Hevi-Rail’s dedicated website: hevirail.pbclinear.com for downloadable materials and other application examples.
Tags
crt, heavy duty bearing, hevi-rail®, nuclear reactor, pbc linear
Hevi-Rail®: The Original Heavy Duty Bearing Pacific Bearing Product Announcements & Manufacturer News 0 04-13-2009 01:13 PM
Linear bearings and rail? CNCCajun Linear and Rotary Motion 1 04-06-2009 09:01 AM
135 Year Old Foundry Refurbishes Production Line with Hevi-Rail® Pacific Bearing Product Announcements & Manufacturer News 0 01-23-2009 10:52 AM
Linear supported rail source CNC Brute DIY-CNC Router Table Machines 3 01-08-2004 10:07 PM
