Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > Product Announcements & Manufacturer News
Product Announcements & Manufacturer News If you are a manufacturer or company with relevant news related to machining or have a new product announcement you may post it here only! (Commercial Posting Forum)
Old 05-07-2009, 09:03 AM
aymancom1 is on a distinguished road
Question halp me to treat the 300 alarm
Hi all
please halp me for recover this problem, I have a CNC lathe machine it faced an accident during the transportation caused damage in the outside frame steel I had to take off the following:-
1- The Screen unit (Fanuc oi )
2- The control panel keys unit (Fanuc oi )
3- The z-axis motor cable
And after I had finished the steel treatment I assembled it again,
When I turn on the machine I found two alarm :-
( APC 306 & APC 300 )
I turn off the machine and when I turn on it again the alarm APC 306 disappear ,Now the alarm APC 300 is still appear I Know that is request for reference posithin return to ZRN Z-axis. i want to know how I can treat this matter step by step . (clearly) i already read the manual for this alarm but it is not clear
Old 05-07-2009, 12:10 PM
yours_prabhat is on a distinguished road
Originally Posted by aymancom1 View Post
Hi all
Hold the can+P button button and power on the mcahine , your problem will get solved If still u find any problem you are free to mail me on prabhatmishra@mail.com
Old 05-08-2009, 12:50 PM
thanks yours_praphat for your reply
But are you sure to press P + can and open the machine
please note that i must pess shift to active P botton, or you mean press O
then I will press O + Cancel and open the machine
in the mintenance manual note me to discover alarm 300 that i must set the parameter 1815#5 to 0 and excecute manual refrance position then press RESET to release the alarm But i don;t know hoe to make it step by step
Old 05-09-2009, 01:34 AM
johnren2000 is on a distinguished road
john
Hello,
This is johnren2000@gmail.com. I am a Fanuc and Siemens Control experter.
if you have any question, lease e-mail to me.
john
Hi all
Old 05-09-2009, 10:19 AM
this is a problem * When the resolution is 0.0001mm, set the value in the unit ten
times the detection unit.
#7 #6 #5 #4 #3 #2 #1 #0
1815 APC APZ OPT
#5 APC 0: Position detector is other than absolute Pulsecoder.
1: Position detector is absolute Pulsecoder.
Try to check the pulse coder cable and connection between motor and control also check your PMC and if you still feel difficulty please mail me on prabhatmishra@mail.com
Old 05-09-2009, 12:47 PM
Thank you very much
i contacted the factory who tell me that how to discover this alarm, the machine is good and normal now, i followed this factory steps
1).Make the parameter can be write , the step as below:
a). Choose the switch to “MDI” mode.
b). Press the function key of “OFFSET/SETTING”; Press the soft key of [SETTING]
C). Move the cursor to parameter “PWE” ( Mean can be write), set to “1”, namely press the key of “1”, then press the key of “INPUT”, the alarm of “No. 100” occur.
2). Move the machine to the scheduled reference position
Under “JOG” mode, move the machine to the reference point position ( the reference point of Z axis, can be set freely), if there is overtravel alarm occurred in the moving, please change the setting value of “inspection of axis traveling” parameter is (No1320, No1321).
3). Setting the parameter, the step as below:
a). Choose the “MEMORY PROTECT” key to OFF position, press the function of “SYSTEM”, press the soft key “PARAM” under the screen, enter to the parameter screen.
b). Enter the parameter No1815 , press the soft key of [NO.SRH] under the screen.
c). Check the setting value of #5 of parameter No1815 is “1”, if it is “0”, move the cursor use “→” to #5 of paramter No1815 , enter the setting value to “1”, press “INPUT” key, the “No 000” alarm will occur(need power off), then power off the power ,and power on again.
d).Index the parameter No1815 again, move the cursor use “→” to #4 of paramter No1815 ,enter the setting value “1”,press “INPUT” KEY. the “No 000” alarm will occur(need power off), then power off the power ,and power on again.( Note: the sequence of parameter is: #7 #6 #5 #4 #3 #2 #1 #0)
e). Make the parameter write closed, namely setting the parameter “PWE” to “0”.
f). Execute “ G91 G28 ZO;”,( For safety, make the rapid override slower), for return to reference point, for checking the setting is finished.
6. After the reference point finished, customers can set the parameter value of “No.1320,No.1321” according to the different use.
7. After all setting finished, start the machine, and check if all functions are ok.
Material Growth During Heat Treat PinMan General Metalwork Discussion 18 12-22-2008 07:27 AM
Need halp with first CNC graciocues CNCzone Club House 2 03-20-2008 04:55 AM
heat treat 420 ss rusticr6 General Metalwork Discussion 0 08-28-2007 01:51 PM
Undersize Threaded Holes After Heat Treat Newby2 General Metalwork Discussion 22 01-01-2007 04:43 PM
Planes In Hole Over Treat WallCrawler CNCzone Club House 0 04-15-2004 12:08 PM
