| Product Announcements & Manufacturer News If you are a manufacturer or company with relevant news related to machining or have a new product announcement you may post it here only! (Commercial Posting Forum) |
| NEW! H2 Compact (All-in-One) Controller! H2 Compact Controller is the 4D CNC controller of H2 PCB, which is a case-mounted, ready-made complete controller with power supply unit and active cooling system. All of its specifications and adjustments are the same as those of the PCB version. This is a real all-in-one type controller. Main technical features: - Step/Dir system, controlled through the LPT port, stepping motor controller, - 4D (with 4 motors), compact build-up, - 2-phase, bipolar, micro-step motor control, - Micro-step values, selected by jumpers: 1; 1/2; 1/8; 1/16, - Power-output with maximum 3.5A DC for each motor, - Mixed mode current decay with PWM regulation, - Motor Power: 160VA, 30V DC, - Silent holding path operating mode, - Maximum 100kHz stepping frequency, - Software controllable motor-rest, - 4-range, jumperable, motor current regulation, - 5 input ports (prepared to use end position and digitallable switches), - 1 relay output (one-pole, maximum load 230V, 3A), - 2-bit TTL expansion port, - Build-up that needs only one power supply voltage (with integrated switching digital power supply), - Protection against overheating, - Installed Fan cooling, - Two-sided, partly SMD PCB CNC control softwares that can be used: - Mach3 CNC (Win2000, XP) [recommended], - TurboCNC (DOS), - WinPC-NC (XP), - CNCGraf (DOS), - JediCut, - GMFC, - CeNeCe, - Stealth Plane Works: FoamCutter, - etc. http://www.hobbycnc.hu |
| cheap ebay controller and power supply questions. | aristoi | Controller Cards | 2 | 04-01-2009 11:25 AM |
| Unipolar Motors, Power Supply, and 3 Axis Controller | Nightwork | Stepper Motors and Drives | 1 | 12-06-2007 07:04 PM |
| DIY Controller Board Power Supply | Fish4Fun | Open Source Controller Boards | 5 | 03-29-2007 04:43 PM |
| Spectralight isa card and power supply/controller | thx1138 | Stepper Motors and Drives | 0 | 08-19-2006 12:32 AM |
| Controller and Power Supply Recommendations | awilcox | Stepper Motors and Drives | 0 | 04-11-2006 01:37 PM |
