Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > Product Announcements & Manufacturer News
Product Announcements & Manufacturer News If you are a manufacturer or company with relevant news related to machining or have a new product announcement you may post it here only! (Commercial Posting Forum)
Old 04-26-2009, 11:03 PM
syil is on a distinguished road
SyiL X6 Plus CNC Release.a linner motion cnc machine.High procision.1400Lbs.
SyiL X6 Plus CNC Release.a linner motion cnc machine.High procision.1400Lbs,Affordable Cost.
package info:
X6 Plus will be include those parts become standard parts:
1,stand,2,table cover and oil tary.3,computer arm.4,coolant system.5 MPG.
Technical info:
Weight: 700KG
Working travelling:
X: 600mm
Y: 300mm
Z: 240mm
Working demention:
300*1000mm
T slot: 16mm
Spindle type: R8/MT3/SK30
motor speed:3500rpm
more info please consult our dealer,and video will post later.
xushuo
Syil.china
ID:	80333   Click image for larger version
ID:	80334   Click image for larger version
ID:	80335   Click image for larger version
Direction,Commitment,Follow through
Old 05-12-2009, 06:06 AM
Have been export..more details consult local dealer
Old 05-12-2009, 06:26 AM
ToolMach_Aust is on a distinguished road
xushuo.
You need to change the specs.
The X travel is only 480mm not 600mm.
Can you show some closeup photos of the side of the cabinet and the plugs/sockets.
What size are the Steppers and Voltage?
cheers
Frans
package info:
Technical info:
Weight: 700KG
Working travelling:
X: 600mm
Y: 300mm
Z: 240mm
Working demention:
300*1000mm
T slot: 16mm
motor speed:3500rpm
xushuo
Syil.china
SyiL X6 Plus CNC Release.a linner motion cnc machine.High procision.1400Lbs. syil Syil Products 38 02-03-2011 04:12 AM
New Machine Build- SyiL X6 Standard CNC Release.a linner motion cnc machine.High procision.1200Lbs,Affor iGG1e Syil Products 14 07-27-2010 11:21 AM
Just IN- SyiL X6 Standard CNC Release.a linner motion cnc machine.High procision.1200Lbs syil Product Announcements & Manufacturer News 10 03-30-2009 07:01 PM
New Machine Build- SyiL X4 Speed Master 24000Rpm Release syil Syil Products 34 12-28-2008 03:18 AM
Smooth motion required high feed 3 axis surface milling cncjoy Fanuc 11 10-13-2007 02:03 AM
