03-04-2009, 12:52 AM
MP-03 ModIO Pendant Kit now Available. | | Hi,
The MP-03 Pendant Kit is now available for sale. http://homanndesigns.com/store/index...products_id=74
The MP-03 is a Kit of Parts that can be built into a Robust and full featured hand-held Pendant. The Pendant is based around the modbus MC-01 ModIO controller and LCD display. A Mach3 plugin is also supplied that enables easy setup but allows for customisation of the pendants functionality.
Included with the pendant kit is the following documentation and software files: - DXF file of pendant enclosure with cut-Outs
- Schematic diagram for the Pendant wiring
- GCode .tap files for milling the enclosure
- MP-03 Pendant Mach3 Plugin.
Please note: This is a Kit of parts and not an assembled unit. You will need to have moderate soldering and electrical wiring skills. Additionally, you will need to mill out the enclosure cut-outs. As an option you can have the enclosure pre-milled if necessary.
Cheers,
Peter.
__________________ -------------------------------------------------
Homann Designs - http://www.homanndesigns.com |
