Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > Product Announcements & Manufacturer News
Product Announcements & Manufacturer News If you are a manufacturer or company with relevant news related to machining or have a new product announcement you may post it here only! (Commercial Posting Forum)
Old 12-13-2004, 04:42 PM
TomHay is on a distinguished road
Polyurea Hardcoats
Though I do not represent a company I have extensive knowledge in the application of Polyurea Hardcoats for over Architectural Foam and would be happy to answer any questions. This would be the ultra hard plural component coating that cures in 6 seconds.
Great Day,
Tom
Old 12-13-2004, 07:52 PM
mrbaseball is on a distinguished road
Exclamation More Info Please
Hello,
I am intersted in hearing more about this product. Once applied can this be sanded?? How much does it cost?? What suppliers have it? What amounts are available? Pints? Quarts? 5 gallon buckets Any additional information would be very helpful. I have been using foam to creat molds for years and I have always had to coat it with bondo to get a lasting hard surface that would hold up to vacuum forming, etc
Thanks in advance!!
Old 12-13-2004, 08:02 PM
Yes it can be sanded. Polyureas also come in many differant hardness or to the point of rubber with over 1,800% Elongation. The one with more Rubber can be used in molds to take 180 degree or better bends. Amber Chemical is but one of many MFG. The product is Volitile Free (no Solvents) and 100% Solids so you lose no product in evaporation. Most of your newer buildings have the Architectural Foam with Polyurea for Colums, Window Awnings. The Theme parks such as Disney and Epcot use it as well and I do not believe you will see a Movie Set today without some construction of it.
Old 12-13-2004, 08:05 PM
Is this the stuff we're talking about??
http://www.pacificurethanes.co.nz/po...utura_5321.htm if so where can this be found, any local suppliers like Home depot or is it a specialty item??
thanks
Old 12-13-2004, 08:12 PM
Yes, it is a specialty item, this shows but a few things done with it.
http://cuttingedgefoam.com/mouldings/index.html
Old 12-13-2004, 08:16 PM
So where can I get it from?? any suppliers you recommend??
Old 12-13-2004, 08:26 PM
I like Futura but I find Engineered Polymers to offer a wider variaty.
http://www.engineeredpolymers.net/
Old 12-16-2004, 07:26 AM
thuffner3's Avatar
Gold Member
thuffner3 is on a distinguished road
Powdered product???
Morning Tom,
I looking to do something along the lines of powder coating, then spraying the catalyst or hardner onto it. Is this something that is feasable with these products? I want to build up layers to acheive the finished object.
Neil
Polyurea over Architectual Foam TomHay Employment Opportunity 8 09-06-2006 12:09 PM
