Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > Product Announcements & Manufacturer News
Product Announcements & Manufacturer News If you are a manufacturer or company with relevant news related to machining or have a new product announcement you may post it here only! (Commercial Posting Forum)
Old 11-25-2008, 10:42 AM
Pacific Bearing is on a distinguished road
Post Withstand the Test of Time with Simplicity® Technology
Rockford, IL – November 22, 2008 Through years of testing, use, and advancement, the PBC Linear Simplicity self-lubricating bearing has stood the test of time. Providing smooth, quiet linear motion in the harshest of applications, this bearing has replaced failing ball bearing technology for over 20 years. Serving as a foundation of innovation for PBC Linear, Simplicity technology is often called by loyal customers, the “little red bearing” that keeps on going.
Developed in 1982, Simplicity was a solution to be directly interchanged with failing standard ball bearings. Since then, we have added many options, including precision and compensated, open and closed, and self-aligning. Where ball bearings can seize and catastrophically fail, Simplicity bearings will out-perform and can last years longer. Whether the application is extreme temperature, dirt, submersion, or high vibration, the Simplicity linear bearing can tolerate almost anything.
From carpet tufting, granite cutting, or foundry-work, the Simplicity linear bearing has proven itself in extreme environments without failure. The FrelonGOLD® or FrelonJ® liners help by eliminating the need for lubrication and metal to metal contact, outstanding performance in a wide temperature range (-400°C to 400°C), lowered wear resistance and friction by 60%, and increased load capacity by 100%. The results are a reduction in downtime, cost savings, and increased overall satisfaction of the customer.
For clean environments, the Simplicity bearing is a great choice as it does not require messy lubrication, does not emit harmful particulates, does not contain moving parts with the potential for failure and, with the patented FrelonJ liner, can be used in most wash down and submersion application. Offered in Inch, Metric and Japanese metric sizes, Simplicity with FrelonGOLD technology has proven itself in the harshest environments, as well as surroundings where the cleanest linear motion is vital.
For more information on Simplicity bearing technology, please call 1.800.729.9085, email to marketing@pacific-bearing.com or visit us at www.pbclinear.com.
Old 03-10-2009, 10:05 AM
Hello,
For additional information on Simplicity self-lubricating linear bearings, please contact us at 1.800.729.9085, email to marketing@pacific-bearing.com, or visit our site specifically devoted to Simplicity at RST.pbclinear.com.
Thanks, and have a great day!
Tags
linear bearings, pacific bearing, pbc linear, self-lubricating, simplicity
Painting hardwood sign to withstand direct sunlight/wx spoiledbrat WoodWorking 3 07-09-2007 11:05 AM
milling time (not to be confused with hammer time) barefoot0 G-Code Programing 4 05-02-2007 06:18 PM
X2 Conversion Time (shopping time) Micro Rotors Benchtop Machines 2 03-04-2007 11:11 AM
Why doesn't discuss the technology? hkxy Laser Engraving & Cutting Machines 4 10-10-2006 12:05 AM
Delagrange Technology LLC. roni21702 Stepper Motors and Drives 2 04-16-2006 03:41 PM
