| Product Announcements & Manufacturer News If you are a manufacturer or company with relevant news related to machining or have a new product announcement you may post it here only! (Commercial Posting Forum) |
KL-1500 Milling Spindle $690 OD=80 MM x 175 MM Voltage: 220V Speed: 6000-24000 R/min Power: 1500 W, Frequency:400 Hz Water Cooling, ER11 collet chuck Grease Lubrication, NSK Bearing KL-2200 Milling Spindle $849 OD=100 MM x 252 MM Voltage: 220V Speed: 8000-24000 R/min Power: 2200 W, Frequency: 400 Hz Water Cooling, ER20 collet chuck Grease Lubrication, NSK Bearing http://www.kelinginc.net/CNCSpindleandController.html http://www.kelinginc.net/CNCSpindleController.html |
| These spindles look attractive but there are almost no specifications at all. What are the part numbers and ABEC class of the bearings, what is the bearing arrangement (duplex on the nose, etc.), what is the guaranteed spindle runout, etc? Is the water cooling intended to be once-through or can it be recirculated from a reservoir? Is there a specified maximum water inlet temperature? Is the duty cycle 100% with the water cooling? Thanks, Randy |
| variable speed dial reconnection, or drive belt change? | klysons | Tree | 1 | 06-29-2007 10:30 PM |
| variable speed drive is it to big | 69owb | Servo Motors and Drives | 1 | 01-02-2006 05:44 PM |
| variable speed dc drive | DragnsBane | General Electronics Discussion | 5 | 02-08-2005 09:07 PM |
| Variable Frequency Drives...how do they work? | mastercnc | General Electronics Discussion | 4 | 05-27-2004 09:59 PM |
