Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > Product Announcements & Manufacturer News
Product Announcements & Manufacturer News If you are a manufacturer or company with relevant news related to machining or have a new product announcement you may post it here only! (Commercial Posting Forum)
Old 07-11-2008, 01:15 PM
Tormach is on a distinguished road
New CNC Lathe / Manual Lathe
For Immediate Release
Contact:
Greg Jackson
President
Tormach, LLC
204 Moravian Valley Rd, Suite N
Waunakee, WI 53597-2514
(608) 849-8381
gjackson@tormach.com
Tormach Introduces CNC Lathe as Mill Accessory
Patented low cost accessory transforms CNC mill into a CNC lathe
Waunakee, WI, July 11, 2008 - Tormach LLC, innovators of CNC technology, announced today the introduction of the Duality Lathe. The patented lathe design, in combination with Tormach's CNC mill, provides CNC lathe functionality for less than $1150.
The Duality Lathe is an entirely new concept in CNC mill accessories. With this integrated space saving lathe a part can be both CNC turned and milled in a single setup. When mounted on a PCNC 1100 mill this accessory can be used to not only turn your parts but also do milling operations such as flats, cross drilling, slotting and contouring. When mounted on your bench top the Duality Lathe is used in manual mode eliminating the need for a separate manual lathe.
Mounted to the table of Tormach's PCNC 1100 mill, the Duality Lathe becomes a CNC lathe. Mounting the lathe is as simple as mounting a machine vise. Two cables, a power cable and a signal cable, provide integration of the mill and lathe control systems. The combined system offers CNC turning, cut-off, boring, drilling, and threading. The Duality lathe includes a quick change tool system, dedicated lathe control software, and an extensive operating manual. Programming wizards allow complicated parts to be created without CAM software. The Duality Lathe also includes spindle clamp and index wheel, allowing milling operations to be performed on parts while they are still mounted in the lathe chuck.
”With this invention we are enabling our customers to leverage their investment in a CNC mill by providing CNC lathe capacities for a fraction of what it would normally cost." says Tormach CEO Greg Jackson. “The Duality Lathe is the perfect solution for entrepreneurs, researchers, inventors and educators, where shops have limited budgets and only occasional need for a CNC lathe."
About Tormach:
Tormach manufactures CNC machinery and accessories designed specifically to address the needs of entrepreneurs, research, development, education, small business, and home shop machinists. Tormach industrial equipment is easier to use and lower in cost than conventional equipment and is particularly well suited to prototypes, secondary operations, and short run manufacturing. For further information visit www.tormach.com.
Old 07-28-2008, 06:08 PM
brianklein is on a distinguished road
This CNC Lathe is less than $1100.00!!! Do you have any more information about it???
Old 07-28-2008, 06:33 PM
ironDigit is on a distinguished road
even more then that brian ?
maybe they should send you one for evaluation.
It is in fact a manual lathe ,adapted to be fitted easily onto a tormach pcnc milltable.
or thats what i got from reading like suggested at tormach.com.
real nifty if i was asked.
Finally CHIPS you can have as much as you can without the doc. complainting about your cholesterol.
manual lathe convert cnc/manual lathe kakayo Vertical Mill, Lathe Project Log 3 02-21-2010 02:13 PM
How to convert Manual Lathe to CNC Lathe? zaid General Metal Working Machines 4 02-07-2008 01:42 AM
Thoughts on a Manual/CNC lathe squarewave CamSoft Products 3 03-20-2006 06:41 PM
TWS lathe manual needed MHINK General Metalwork Discussion 0 08-02-2005 11:01 PM
manual lathe 723 General Metal Working Machines 1 04-29-2004 02:32 AM
