Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > Product Announcements & Manufacturer News
Product Announcements & Manufacturer News If you are a manufacturer or company with relevant news related to machining or have a new product announcement you may post it here only! (Commercial Posting Forum)
Old 09-10-2004, 12:54 PM
icm icm is offline
icm is on a distinguished road
3D/2D PIC PWM Step/Dir CNC Controller
Technical specifications:
- Standard, 3-axis or 2-axis (3D or 2D), Hybrid/Native PWM, Step/Dir-system CNC motor control.
- Unipolar motor drive, with 12 pieces of Logic Level MOSFET power transistors (with integrated protecting supressor diodes).
- Possibility of mounting an external optional heat sink (for the FETs) (not necessary if load does not exceed 2.5A/phase).
- Input voltage and power supply range of the motors: 8 ... 50 V or 8 ... 90 V
- Maximum driving phase current of motors : 18A (above 2.5A heatsink is necessary, above 5A reinforcement of conductor stripes of PCB is necessary).
- Minirelay with potential-independent make contacts for controlling the turning motor or the filament (maximum. ~250V, 5A).
- PC interface: standard CETRONICS interface female for standard printer cables (LPT port).
- Microcontroller: any 40-pin member of the PIC16F87x (16F871 ... 16F877) family with 20MHz clock.
- Step/Dir signal detection (by the means of two-way counters).
- Full galvanic separation from the PC, by the means of opto-couplers.
- Built-in 5V supply (necessary input voltage: +8 ... +12V).
- Built-in ICP (In-Circuit Programing) interface, for uploading Firmware/Setup.
- PCB-integrated PIEZO speaker (for signal sounds)
- 3 pieces LED drive (Power supply, LED1, LED2) for combinated signals.
- 1 push-botton for obtaining signals and functions.
- Full compatibility with Hobby and Profi Firmwares.
- Serial datalink (PC-Link). Direct Setup uploading (PWM) and extended diagnostics.
Please visit: http://magiist.free.eplanet.hu
Old 09-10-2004, 01:02 PM
CNCadmin's Avatar
Site Owner
CNCadmin has disabled reputation
Nice stuff!
Thank You,
Paul G
Site Owner-Webmaster-
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 09-11-2004, 03:24 PM
uucww's Avatar
uucww is on a distinguished road
good!!
Old 09-11-2004, 06:11 PM
mvaughn's Avatar
Moderator
mvaughn is on a distinguished road
now thats a HEAT SINK!!!
Mark
Check Out My Build-Log(s):
http://cnczone.com/forums/showthread.php?t=4716
CNC Router Version 1 [====================] 100%
http://cnczone.com/forums/showthread.php?t=39294
CNC Router Version 2 [=|-----------------------] 5%
Old 09-12-2004, 02:16 AM
icm icm is offline
Thank You!
www.hobbycnc.hw.hu
Old 09-12-2004, 03:44 AM
ynneb's Avatar
Moderator
ynneb is on a distinguished road
That is a very nice web site you have icm.
I have saved your whole site to view in detail.
It is a good thing that pictures are the international language.
Welcome to CNCzone.
Old 09-12-2004, 03:56 AM
icm icm is offline
Greatly I thank!
If better I would be aware of in English, more would translate the Hungarian version...
Old 09-19-2004, 10:05 AM
Ito-Brazil is on a distinguished road
Exclamation wow
My deams´PCB !!!!!
WELL DONE !!!!!!
AMAZING !!!!
CNC Controller PIC 16F877 - From Brasil elizeu PIC Programing / Design 12 05-04-2009 08:49 AM
CNC controller osdhillon General CNC (Mill and Lathe) Control Software (NC) 8 11-06-2007 11:13 PM
Open Source CNC Controller Specification gregmary DIY-CNC Router Table Machines 28 12-04-2005 10:58 PM
pic chip SERIAL to step/dir and controll berin Open Source Controller Boards 13 02-18-2005 06:23 PM
3D or 2D MAXI Style Hobby CNC PWM Controller! icm Product Announcements & Manufacturer News 1 01-05-2005 09:36 AM
