Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > Product Announcements & Manufacturer News
Product Announcements & Manufacturer News If you are a manufacturer or company with relevant news related to machining or have a new product announcement you may post it here only! (Commercial Posting Forum)
Old 04-16-2008, 09:21 PM
northernmach is on a distinguished road
Improved Tap Wrench! Self Centering!
This is an updated anouncement which was posted before but many are trying to go to links which are no longer available and, I thought it would be best to repost with updated links. The following is the original post with the updates:
I would like to announce a push we are making at Northern Machining Inc. to try and test the marketability of our improved tap wrench.
Please visit the following link for more info: I would like to announce a push we are making at Northern Machining Inc. to try and test the marketability of our improved tap wrench.
Please visit the following link for more info: http://cgi.ebay.com/ws/eBayISAPI.dll...TODAY.m238.lVI
To check out a video showing how it could be used in a milling machine, or drill press.
The most important realization to make, is that this design keeps the tap centered with the spindle in the machine. Not all taps come with a center hole for supporting the tap when running it in by hand, with a tap wrench. This causes one to try and tap without proper upper support and many times can result in a broken tap which can not only be expensive for the cost of the tap, but also can leave the broken tap in the part that is being worked on, which in alot of cases can only be removed with the use of an EDM which can be a very expensive process.
Our wrench gives multiple options for the upper support needed to remove risk of breaking a tap!
Thanks for taking the time to check out our product, and any suggestions or comments are welcome!
I also highly recomend taking the time to visit the following site where much feedback as been given on this wrench at the following site:
http://www.cnczone.com/vb...d.php?t=155544
Regards,
Chad Ashley
chad@northernmachininginc.com
A BETTER TAP WRENCH! SELF CENTERING! northernmach Product Announcements & Manufacturer News 19 08-28-2010 02:13 PM
X-3 Spindle wrench DICKEYBIRD Benchtop Machines 3 12-26-2006 06:20 PM
Mach- Improved tool path display ( see video) ynneb Mach Software (ArtSoft software) 7 12-04-2006 09:53 PM
Improved laser digitizer accuracy Karl_T CamSoft Products 0 12-04-2006 08:24 AM
New and improved chat CNCadmin CNCzone Site News and Contests 0 02-24-2005 09:12 PM
