Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > Product Announcements & Manufacturer News
Product Announcements & Manufacturer News If you are a manufacturer or company with relevant news related to machining or have a new product announcement you may post it here only! (Commercial Posting Forum)
Old 03-31-2008, 01:05 PM
cdw3423 is on a distinguished road
CNC Write Engraving software update
I have made to minor changes to CNC Write. These changes will make old machine G Code files incompatible. Right now there is an "Open Old" button on the machine tab that can be used to open any existing machine files you may have. If you then save them using the save button, that will convert your machine files to new format.
The Machine file format saves all of the settings from the top part of program interface including text height, width, angle . . . Also if you create a machine file with the name "default", that machine file will automatically load every time the program starts.
The new version can be downloaded here CNC Write Download.
Everything else should work the same. You will NOT need a new registration key.
Chris W
New Engraving software CNC Write cdw3423 Product Announcements & Manufacturer News 21 01-26-2011 09:24 PM
Software Update md63825 Bridgeport and Hardinge Mills 8 06-18-2009 04:58 AM
Engraving software calvoeiro Mach Software (ArtSoft software) 9 10-27-2006 08:56 PM
Help with CNC10 install on BPBoss (software update from CNC7) peter.blais AjaxCNC Control Products 8 10-13-2006 11:18 PM
Searching Update EZ Trak Software Holzwurm56 Bridgeport and Hardinge Mills 4 04-29-2006 11:54 PM
