Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > Product Announcements & Manufacturer News
Product Announcements & Manufacturer News If you are a manufacturer or company with relevant news related to machining or have a new product announcement you may post it here only! (Commercial Posting Forum)
  #13   Ban this user!
Old 04-27-2010, 03:36 AM
lmlamb's Avatar
lmlamb is on a distinguished road
Originally Posted by ovidiuse View Post
If have already a DXF to CNC software and you need only edit the leadin and leadout lines probably you need other application.
Can you explain more detailed what tasks should made the software that you need? Maybe I can help you...
Regards
Ovidiu
Ovidiu
You are probably right. The software that I am using to convert DXF to Gcode is called LazyCAM. It is a Beta program by ARTSOFT. Unfortunately, it is no longer supported which makes for a problem. It converts the files very well, but it won't allow me to edit the GUI graphics to remove or change any of the lines.
Basically my needs are simple, 1. convert the DXF to Gcode. 2. Allow editing of the GUI graphics to remove the LEADIN and LEADOUT lines and rapid moves, or 3. Allow conversion without any rapids or LEAD lines.
I am in Germany, so we are in the same time zone. Where in Romania are you at?
Regards,
Larry
Larry
  #14   Ban this user!
Old 04-27-2010, 04:00 AM
ovidiuse is on a distinguished road
Hi Larry,
I think that SoftONE-CNC can do your request, which mean that can make conversion of DXF files and back blot if necessary, edit the length of leadin(leadout) or remove leadin and leadout (=0 in option menu). Also, you can adjust the postprocessor output according to your needs. The next version will give also the possibility for changing the angle of leadin or/and leadout.
If the nesting job contain more than one parts and also from moving of the CNC head from origin to part and viceversa , it is necessary rapid movements. What about you request about removing the rapid lines ? It is about the DXF nesting sketch?
If you consider that SoftONE-CNC application is suitable for your needs, I can remake for you an affordable price.
If you are in Gemany is very good because we are in the same tiemzone. I'm am in the SW part of the Romania, Drobeta Turnu Severin town, but I stay also in Timisoara town (west part of Romania) because there I have also some clients.
Regards
Ovidiu
  #15   Ban this user!
Old 11-28-2011, 12:42 AM
SoftONE-CNC V4
SoftONE-CNC V4 new features:
1) New GUI : Microsoft Office style user interface based on the latest .NET Technology.
2) New Standard toolbars, Status Bars, Tree view
- New info bar window: nesting info and production info;
- New status bar - X/Y tool coordinates shown;
- New simulation toolbar.
- New CNC toolbar and CNC code list view
- new Parts information in Tree View: pos, thickness, block, part area
3) Improved zoom and pan functionality;
4) Nesting edit functions and menu;
- Automatic position numbering
- Change Part Production info: Part name, position numbers, thickness
- Interactive change the lead_in/out angle.
- Interactive change leads length.
- Delete lead
- Delete Part
5) New SoftONE nesting save format (NCE)
6) New customizable Nesting Production Sketch
For more information, visit: http://www.onesoft.ro
Download SoftONE-CNC V4 Description
  #16   Ban this user!
Old 12-05-2011, 07:58 AM
SoftONE-CNC
  #17   Ban this user!
Old 12-12-2011, 06:09 AM
Originally Posted by Kevin2moon View Post
Please tell me how much your products cost, It is not on your web site.
Hi
I sent you PM
Ovidiu
  #18   Ban this user!
Old 03-27-2012, 03:15 AM
Software update
SoftONE-CNC (ONESoft Web site) generates NC-code from Aveva Marine(TRIBON) software CAM “gen” files and AUTOCAD “dxf” files for computer controlled burning machines with plasma arc cutting, gas cutting, laser cutting and other manufacturing applications.
SoftONE-CNC is designed to run in Windows Vista/XP/7.
The new graphical user interface (GUI) is based on last .NET technology with Microsoft user blue style interface for make it easy to learn. A new user can produce reliable NC-code within the first ten minutes of using SoftONE-CNC
Features:
- Works like a graphical NC postprocessor for Tribon and Autocad users
- Read and convert to NC codes bevel instruction from Tribon “.gen” files
- Read and convert to NC codes Autocad DXF files or other software which can export DXF files.
- Kerf tool compensation NC code calculation function - according to the user input kerf value (can be used also by CNC machines manufacturers for calculation of their machine tools compensation);
- Separating process entity by colors
- Export nesting plates to Autocad DXF connecting the geometries on different layers and colors for each process.
- NC code analizing (ESSI and G-Code) and “step by step” simulation through “Back generation” of NC code function (NC code viewer and CNC processes simulation)
- Back NC code conversion to DXF files
- Read and convert NC code from ESSI to G-Code and vice versa according to users customized SoftONE postprocessors.
- Open contour offset - Allows for single lines to be cut
- All duplicate entities, i.e. identical lines or arcs, are automatically deleted.
- Allows the user to set the lead-in and lead-out length independently. You can create NC-code with no leads, lead-ins only or lead-ins and lead-outs. Avoids damage to the edge of the part
- Interactive change of lead in/out length and angles;
- Delete parts and leads with automatic updated of NC code;
- Material selection features;
- Manually and automatic updating of parts production information; Auto position numbers feature;
- Automatic generation of production nesting sketches; Quick user customizable sketch template using Autocad (DXF) ;
- Quick user customizable sketch template using Autocad (DXF) ;
- Optimize the complete path automatically from the DXF file for reducing the cutting time process. The shapes on each layer are processed from the bottom left corner to the upper right corner.
- Calculates the area of the processed parts, minus any holes. Generate a report for the nesting plate with all necessary information for production
- Simulate on the screen all CNC processes: marking, cutting, idle etc.
- Mark using rapid travel speed.
- Generate marking or cutting path only.
- Allow the user to set-up the input filters, extension of the output NC files, motion settings as well as bevel settings of the resulted file.
- Works with both standards :ESSI or G-codes with or without bevel
More information and detailed description at:
Also, a freeware NC ESSI Viewer is available!
CNC Postprocessor software for CAD/CAM - NC Software for 2 axis, 3 axis, 4axis...
http://www.onesoft.ro/download
http://www.onesoft.ro/products
Best VMC for my application? FTSCNC General Metal Working Machines 7 06-23-2008 09:04 PM
Best software for my application? mulligan CNC Plasma and Waterjet Machines 2 01-30-2008 08:42 PM
Help With a Different Application for a Fanuc 21T AZDEN Fanuc 2 06-14-2007 03:33 PM
What a great application! wholepair Machine Created Art 2 03-23-2006 05:29 AM
Help with a Stepper application? Enzo Stepper Motors and Drives 2 08-22-2005 06:30 AM
