Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > Product Announcements & Manufacturer News
Product Announcements & Manufacturer News If you are a manufacturer or company with relevant news related to machining or have a new product announcement you may post it here only! (Commercial Posting Forum)
Old 07-01-2004, 12:02 AM
Gold Member
imserv is on a distinguished road
Vcarvz now posts G-code
Vcarvz is a text layout and 3D V-cutter carving program. It incises Tru-type text outlines, and will also alternate between incised and relieved contours within a flat DXF contour file. This software tool was originally designed as a supplement to VectorCad-Cam. It is still optimized for use with Vector, but can now also be used with any CNC G-code controller. No intervening Cam programming step is required.
The code is generic and has been tested to work directly within DeskCNC. The DeskCNC editor can simulate the actual V-carving as a rendered 3D surface, running the complete program or single/multiple block stepping.
Sample DeskCNC cut file simulation image here: http://www.imsrv.com/6x3ovalVcarvz.jpg
The upgrade is free to all previous Vcarvz customers. A 30 day demo is available for download at http://www.imsrv.com
Fred Smith - IMService
Old 07-01-2004, 01:13 PM
kong is on a distinguished road
I would like to try the software, but I have been waiting all day for the email with the download link to arrive! Should it take so long?
edit - ok, got it now!
Old 07-07-2004, 12:51 PM
Just had a quick go with the software, and have to admit, I like it!
It is gonna take me a while to get it to produce some clean g-code, I had a few problems with my imported DXF, the code had a few places where it cut the same section twice, particularly on the dot of the letter "i". I am sure this is my fault, I will keep trying. I would also like to see a final finnishing pass, since I had some deep lettering, I cut in three passes, and those are clearly visible on the finnished product. Again, this can be overcome by creating a second code-set at full depth and running after the first set so I am not too worried.
Just thought I'd give it the thumbs-up and show my first cuts, thanks Fred
Old 07-07-2004, 01:19 PM
CNCadmin's Avatar
Site Owner
CNCadmin has disabled reputation
Nice job maybe a review is in order?
Thank You,
Paul G
Site Owner-Webmaster-
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 07-07-2004, 02:46 PM
InventIt is on a distinguished road
One question.
The demo program produced a cut file where the bit was plunging alot. Is this normal? Seemed to do this mostly on curves. Is there a setting I have wrong?
I was using Arial Black text.
Old 07-07-2004, 03:08 PM
Gold Member
That's two questions.
1) no
2) yes
Vcarvz support forum is at http://www.imsrv.com/discus
Increase filter parameter, and possibly text smoothing settings. Keep smoothing as low as possible and still retain smooth curves.
looking for g code 3d from bobcadcam or simmilar for indexer lpt v5 with g code soft troyswood Ability Systems - LPT Indexer and G-Code 2 12-24-2006 10:21 PM
parametric programming Karl_T CamSoft Products 21 05-24-2005 03:58 PM
authorizing code crow Autodesk Software (Autocad, Inventor etc) 2 02-12-2005 03:19 PM
I need sample G code program bunalmis G-Code Programing 1 08-24-2004 04:50 AM
Getting The Most Out of CNCzone's Posting Features CNCadmin CNCzone.com FAQ 0 03-02-2003 12:08 AM
