Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > Product Announcements & Manufacturer News
Product Announcements & Manufacturer News If you are a manufacturer or company with relevant news related to machining or have a new product announcement you may post it here only! (Commercial Posting Forum)
Old 07-05-2007, 08:19 AM
stoogeweb is on a distinguished road
HEIDENHAIN's New LS Linear Scales Offer High Level Scanning Technology
SCHAUMBURG, IL - Equipped with advanced Single-Field Scanning technology and incorporating all the latest developments in linear measurement technology, HEIDENHAIN is now making available their latest sealed linear encoders called the LS XX7 Series. These new scales are available up to 3m in length, come in two different mechanical profiles and offer unparalleled resistance to contamination and vibration making them particularly useful in dynamic machine tool applications.
This new single-field scanning technology provides significant encoder advantages regarding the tolerance to contamination and to electromagnetic noise sources. Along with this improved signal stability, single-field scanning also has proven to improve signal quality providing a typical output signal error of ± 1 % within one signal period.
Along with offering an improved encoder, simple mounting methods are standard with these HEIDENHAIN LS linear encoders in order to incorporate them into a wide variety of applications. Encoders of the LS 400 series can now utilize a universal mounting spar when required which allows for a cable outlet to the left or right. Available accessories also include clamps as an alternative that are mounted at fixed intervals along the measuring length to provide additional support.
Encoders of the LS 100 series have a left and right cable outlet directly on the scanning unit. The unused socket connector is protected by a cap and both encoders of the new series utilize the same cable assembly.
For more information on these linear encoders, contact HEIDENHAIN at (847) 490-1191, or write to us at HEIDENHAIN CORPORATION, 333 E. State Parkway, Schaumburg, IL 60173. HEIDENHAIN can also be accessed directly via our web site at www.heidenhain.com or e-mail at info@heidenhain.com.
HEIDENHAIN CORPORATION is the North American subsidiary of DR. JOHANNES HEIDENHAIN GmbH, a leading international manufacturer of precision measurement and control equipment. Our product line includes linear scales, rotary and angular encoders, digital readouts, digital length gages, CNC controls and machine inspection equipment.
Working out the required length of linear glass scales hotponyshoes General Metalwork Discussion 7 06-24-2008 08:03 AM
Connectors on glass linear scales - interchangable? hotponyshoes General Metalwork Discussion 0 05-17-2007 01:56 AM
Sorce of used linear glass scales / encoders hotponyshoes General Metal Working Machines 2 05-14-2007 01:17 PM
VM-3 Linear Scales? 100 Haas Mills 7 03-04-2007 11:31 PM
fanuc 6 and ttl linear scales skippysmt Fanuc 2 02-25-2007 05:56 PM
