| Product Announcements & Manufacturer News If you are a manufacturer or company with relevant news related to machining or have a new product announcement you may post it here only! (Commercial Posting Forum) |
Portable CNC Cutting Machine Makes CNC Cutter Affordable for Medium and Small Enterprises ESS Ltd., an innovative China-based supplier of cutting equipments, has launched to the global market a mile-stone Portable CNC cutter which is affordable for all small and medium enterprises. The company already has a great success in its domestic market in this business and is looking for the global market. Looks somehow like a semi-automatic cutting trolley but with a cross beam on its central unit moving on the x-axis, the portable cnc cutting machine is a wonderful mixture of a simple machine with cnc profile cutting features. Before SteelTailor is in the market, enterprises have to pay tens of thousands of dollars for a gantry or bench type cnc cutting machine. It is a heavy investment for a small business. Also it is a waste for the CNC cutting machine owners to cut small parts with a big cutting machine. It is not only the high cost that restricted the application of gantry and bench CNC cutting machines. These types of big CNC cutting machines are fixed in a workshop and it takes much space. In many applications, the cutting operation needed to be carried out at the site where the steel plates are stored. It is nearly impossible to move a big gantry or bench CNC cutting machine from one location to another only for a temporary task. What is to be moved is only the metal sheets. Apart from the big CNC cutting machines, the small profiles are cut by conventional profile cutters such as pantographic cutters. Some blanking is made by straight line cutters or trolley cutter as they are called in some countries. SteelTailor P solved all the problems. It is a small CNC profile cutter and low cost Technical parameters Type HBST2005LCD – 1200 x 2000 Input Voltage 110/220 V Frequency 60/50 Hz Input Power 180 W Display LCD 5.7 ˝ Effective Cutting Range X-Axis: 1200 mm Y-Axis: 2000 mm (see note 1) Moving Speed 0 – 1000 mm/min (flame) Cutting Thickness (Flame) 6 – 150 mm Cross Beam Length 1700 mm Longitudinal Rail Length 2500 mm (see note 2) Cross Beam Weight 9.3 kg Host Machine Weight 26.7 kg Longitudinal Rail Weight 34.5 kg Total Machine Weight 70.5 kg Mode of Cutting Flame or Plasma Combustive gas Oxygen Combustive Gas Pressure Max 1.5 Mpa Fuel Acetylene – Propane – Methane – Gasoline (see note 3 and note 4) Fuel Pressure Max 0.1 Mpa Cutting Speed (Flame) 0 – 600 mm/min Cutting Software FastCAM Basic Version (see note 5) ![]() ![]() ![]() http://www.steeltailor.com
__________________ denniswang http://www.opetrol.com <a href=”http://www.opetrol.com”>cutting torch</a> |
| New products SteelTailor Portable CNC Cutting Machine | denniswang | Product Announcements & Manufacturer News | 5 | 09-14-2011 10:10 PM |
| Introduce One Portable CNC Cutting machine | denniswang | Product Announcements & Manufacturer News | 0 | 04-24-2007 05:13 AM |
| small to medium CNC milling machine advice | slow_rider | General Metal Working Machines | 7 | 10-12-2006 06:39 PM |
| SteelTailor portable CNC Cutting Machine | William0008 | General Metal Working Machines | 0 | 09-05-2006 11:17 PM |
