Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > Product Announcements & Manufacturer News
Product Announcements & Manufacturer News If you are a manufacturer or company with relevant news related to machining or have a new product announcement you may post it here only! (Commercial Posting Forum)
Old 04-24-2007, 05:13 AM
denniswang is on a distinguished road
Introduce One Portable CNC Cutting machine
Portable CNC cutting machine can cut any complex plane figures as the large-sized gantry CNC cutting machine and support both flame torch and plasma cutter. It is affordable for all enterprises and workshops. The compact design and rational structure make it lightweight,small size and easy to move. It is usable both indoors and outdoors.
By using high quality controllers in its automation system and antimagnetic materials in its housing, SteelTailor P guarantees a reliable and stable CNC operation.
The application of the most up-to-date CNC technology allows independent programming from numerical control . equipment failure and maintenance difficulty are reduced.
The integration of FastCam cutting software makes drawing, nesting and cutting simple and efficient. The software provides high level of material utilization & optimization.
Technical Data
Input Power 220V/110V 50-60 Hz
Rated Power 180W
Efficient Cutting Range X Axis :1200 mm(47")-Y Axis:2000 mm( 78")
Y Axis: Can be extended till 5500mm(216")
Dimensions of LCD 5.7"
Cutting Thickness( Flame ) 0.2"-5.9"(6-150mm )
Weight 70.5kg (156 lbs)
Type of Cutter Oxy - Fuel or Plasma
Applicable Cutting Fuel Acetyene,Propane,LPG,Gasoline
Fuel Pressure Max.0.1MPa (14.5 PSI )
Oxygen Pressure Max.1.5MPa (218 PSI )
Cutting Software FastCam
Z Axis Manually Adjustable, Inclinable
http://www.steeltailor.com
denniswang
http://www.opetrol.com
<a href=”http://www.opetrol.com”>cutting torch</a>
New products SteelTailor Portable CNC Cutting Machine denniswang Product Announcements & Manufacturer News 5 09-14-2011 10:10 PM
introduce new 0.2mm small hole drilling EDM machine Robine Product Announcements & Manufacturer News 0 03-28-2007 03:14 AM
Need CNC Machinists to manufacture our Portable Machine Tools for innovative uses! CPMT-HR Employment Opportunity 0 03-22-2007 07:14 PM
SteelTailor portable CNC Cutting Machine William0008 General Metal Working Machines 0 09-05-2006 11:17 PM
I need help about cutting heads which apply to apparel pattern cutting machine sheepgrass Mechanical Calculations/Engineering Design 0 05-12-2006 01:09 PM
