Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > Product Announcements & Manufacturer News
Product Announcements & Manufacturer News If you are a manufacturer or company with relevant news related to machining or have a new product announcement you may post it here only! (Commercial Posting Forum)
Old 04-04-2007, 08:36 AM
aceprotech is on a distinguished road
A.C.E. Production Technologies Provides Line of Simple, Affordable Lead-Free Solderin
ACE Production Technologies is a designer and builder of simple, affordable selective soldering systems suitable for leadfree solders based in Spokane, Washington. Our rugged, reliable, and compact, line consists of the KISS 101, KISS-102, KISS-103, and the KISS-104.
All of these flexible systems feature leadfree compatible solder pots and are ideal for low to medium volume assembly, prototyping, and rework, postreflow offline assembly and other soldering applications such as oddform devices.
The KISS-101 is simple to set up and use, features analog controls, and provides the kind of flexibility needed in a quick-turn rework or light assembly facility. It can accumulate PCB's from 2" x 2" up to 18" x 24", and connectors up to 10" long. Its footprint is 30" x 32".
The programmable KISS 102 is a fully automated machine that uses the proven 'traveling mini-solder wave. This system overcomes the limitations of operator-dependent soldering with a truly flexible molten solder delivery system. It is designed to fill the gap between hand soldering and more expensive automated in-line robotic selective soldering. The KISS 102 couples higher throughput with precise process controls. The programmable features provide the tools to set all process parameters, including immersion depths, pre-heat dwells, travel distances and speeds, solder temperature, and wave height. Once set, the system will repeat precisely. It can be programmed via a laptop computer. The dimensions and part handling sizes of the 102 are the same as those of the 101.
For more information, please visit http://www.ace-protech.com, or contact:
Spokane, WA
(509) 924-4898
(509) 533-1299 fax
Terminating a simple line john_mccarron GibbsCAM 5 03-11-2007 08:55 AM
Perhaps a bug in simple one line code?? thuffner3 TurboCNC 3 02-02-2004 08:21 PM
