Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > Product Announcements & Manufacturer News
Product Announcements & Manufacturer News If you are a manufacturer or company with relevant news related to machining or have a new product announcement you may post it here only! (Commercial Posting Forum)
Old 12-14-2006, 03:03 AM
sinonsh22 is on a distinguished road
NSH GER Used Engine Oil Purifier machine
Application
NSH GER Gas engine oil recycling System is particularly suitable to recycle internal-combustion engine oil including diesel engine oil, gasoline engine oil and internal-combustion engine oils. GER series can effectively remove colloid, oxid, acid, pitch, particles, impurities, water, gas in the oil. Specially, GER can restore the color of used internal-combustion engine oil and remove the scent rapidly.
Advantages of GER
Design according to different needs of customers.
Purify blend oils.
Low operation cost.
Low maintenance and replacement expenses.
High regeneration rate.
Automatic reverse wash system will extend the lifetime of filters and improve the performance of the filters.
High performance security system including pressure protection device and automatic temperature controller makes purifier operate safely.
Small size, light weight, low noise.
Other Product Catalogue
Insulation Oil Series
VFD Double-Stage High-Efficiency Vacuum Insulation Oil Purifier
VFD-A Double-Stage Vacuum Insulation Oil Automation Filtration
VFD-R Double-Stage Vacuum Insulation Oil Regeneration Purification
VFD-T Double-Stage Vacuum Insulation Oil Purifier with Tester
GER Gas Engine Oil Regeneration System
Turbine Oil series
TF Turbine Oil Recondition
TF-A Turbine Oil Automation Reclamation
TF-R Turbine Oil Regeneration Reclaiming
Lubrication Oil series
LV Lubrication Oil Filtration
LV-A Lubrication Oil Automation Filtering
LV-R Lubrication Oil Regeneration Filter
Flame-resistant Oil series
FV Flame-resistant Oil Recycling
FV-A Flame-resistant Oil Automation Recycle
Explosion-proof series
EV Explosion-proof Vacuum Cleaner
EV-A Explosion-proof Vacuum Purifier
EP Explosion-proof Precision Filtering Purifier
EP-A Explosion-proof Precision Filtering Purifier
sinonsh22@163.com
http://sinonsh22.en.supplierlist.com
msn:sinonsh22@hotmail.com
Your inquiries are highly welcome at any time, we are ready to make a response during workdays.
