SINO-NSH TF turbine Oil ( oil filtration, oil purification, oil recycling, oil treatment, oil regeneration ) Plant
TF series oil filtration plant is particularly suitable for recycling turbine lubricating oil.It also applys to treat hydraulic, coolant oil and other lubrication in which contain large of water, vapor, impurities, sludge, dielectric and colloid.It can eliminate them effectively and efficiently. TF series will result in the improvement of the properties of turbine oil, other lubrication and extend the maintenance period of turbine or other equipment which has lubrication system and keep them operate in good condition.
SINO-NSH transformer oil purifier plant
SINO-NSH lubricating oil filtering plant
SINO-NSH turbine oil recycling plant
SINO-NSH engine oil regeneration system
sinonsh22@163.com http://sinonsh22.ec51.com
