Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > Product Announcements & Manufacturer News
Product Announcements & Manufacturer News If you are a manufacturer or company with relevant news related to machining or have a new product announcement you may post it here only! (Commercial Posting Forum)
Old 10-26-2006, 12:47 AM
sinonsh22 is on a distinguished road
Sino-nsh LV Lubrication Oil Recovery machine
Application
LV series oil recycling system are suitable especially for recycling and restoring hydraulic oil, machine oil, coolant oil and various other lubrication oil. The most breakdown of machinery which has lubrication oil system results from contaminated lubrication in which has water, gas, impurities etc.LV series can rapidly remove water, gas, particulate matters and impurities from lubrication oil and improve properties of lubricating oil so as to greatly extend lifetime of machinery which has lubrication system.
Features
Perfect capacity of removing impurities. The special filters made by NSH are made of special materials which can eliminate various impurities, water and gas effectively and rapidly.
Automatic reverse wash system will extend the lifetime of filters and improve the performance of the filters.
High performance security system including pressure protection device and automatic temperature controller makes purifier operate safely.
Online work
Easy handling and maintenance.
Lower maintenance and replacement expenses
Small size, light weight, low noise
Available in mobile or stationary options.
Various sizes and configurations (shield) available.
Other Product Catalogue
Insulation Oil Series
VFD Double-Stage High-Efficiency Vacuum Insulation Oil Purifier
VFD-A Double-Stage Vacuum Insulation Oil Automation Filtration
VFD-R Double-Stage Vacuum Insulation Oil Regeneration Purification
VFD-T Double-Stage Vacuum Insulation Oil Purifier with Tester
GER Gas Engine Oil Regeneration System
Turbine Oil series
TF Turbine Oil Recondition
TF-A Turbine Oil Automation Reclamation
TF-R Turbine Oil Regeneration Reclaiming
Lubrication Oil series
LV Lubrication Oil Filtration
LV-A Lubrication Oil Automation Filtering
LV-R Lubrication Oil Regeneration Filter
Flame-resistant Oil series
FV Flame-resistant Oil Recycling
FV-A Flame-resistant Oil Automation Recycle
Explosion-proof series
EV Explosion-proof Vacuum Purifier
EV-A Explosion-proof Vacuum Purifier
EP Explosion-proof Precision Filtering Purifier
EP-A Explosion-proof Precision Filtering Purifier
sinonsh22@163.com
http://oilpurifier.ec51.com
Old 10-26-2006, 01:05 AM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
made fwom wecycled pop cans
