Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > Product Announcements & Manufacturer News
Product Announcements & Manufacturer News If you are a manufacturer or company with relevant news related to machining or have a new product announcement you may post it here only! (Commercial Posting Forum)
Old 09-23-2006, 11:00 PM
JennyYin is on a distinguished road
Thumbs up Manufacture laser carving cutting machine
We researched / developed / made the series of the laser engraving machines and laser cutting machines which are applied in the industries: costume / leather / craftwork and gifts / package and printing /models / advertisement and so on.
GS-13070 Laser Carving cutting machine
It is mainly applicable for Clothes Making factories and computer embroider factories, caps making factories, needlework factory and relevant clothing processing factories and fabrics piece cutting etc.
specification:
Laser type Sealing and dispersing type CO2 laser tube
Laser power 75W
Work breadth 1300×700mm
Operating voltage 50HZ 220V±10%
Carving speed 0~1000mm/s
Cutting speed 0~800mm/s
Repetitive positioning precision ±0.02mm
Movement system DSP curve movement control DSP
Complete machine power 1300W
Power control mode Combination of laser energy and movement control
Software Guoshi photoelectricity legitimate software DSP7.0
Overall dimension 1800×1240×1140mm
GS-10060 Laser Carve cutting machine
Applicable for embroidered cloth, fabrics tailoring, punching, lace fabrication, and also applicable to the leather punching, hot bored die-opening, Acryl carving and cutting industries.
specification:
laser type Home-made sealing and dispersing typeCO2 laser tube
Laser power 65W
Work breadth 1000×600(mm)
Operating voltage 50HZ AC 220V±10%
Carving speed 0~1200mm/s
Cutting speed 0~900mm/s
Movement system DSP curve-movement control
Complete machine power 850W
Power control mode PWM laser energy control
Overall dimension 1560×1100×1250(mm)
GS-3040 trademark cutting machine
It is mainly applicable for trademark cutting, bamboo and wood handcraft, pattern carving and punching for leather, hot-bored and die-opening etc.
specification:
Laser type Home-made sealing and dispersing type CO2 laser tube
Laser power 65W
Work breadth 300×400(mm)
Complete machine power 650W
Overall dimension 1360×790×1050(mm)
GS-12060II Multifunctional double head machine
Applicable to clothing tailoring, slice cutting for leather & fabrics , carving & elaborately wrought, computer embroider and cutting; and acryl products, lenses panels, advertising light boxes, crystal words, exhibition counter; packing boxes, models, toys, furniture and other processing industries.
specification:
Laser power 65W×2
Work breadth 1200×600(mm)
Complete machine power 1000W
Power control mode PMW laser energy control
Overall dimension 1767×1280×1350(mm)
GS-D3030 laser trademark making machine
It is suitable to be used in the corium, leatheroid, double color leather, leather marker fabrication, jean and costume accessories etc, such as the mark making, pattern spraying and cutting of materials such as button and decorative pieces etc.
specification:
Laser type U.S. imported radio frequency CO2 laser tube
Laser power (it can select from 40W to 150W)
Working breadth 300×300(mm)
Carving speed 0~10000mm/s
Cutting speed 0~1500mm/s
Power control method PMW laser energy control
Overall dimension 1460×450×1250(mm)
GS-160100 Large breadth Laser Cutting Tools
【Product feature】
1. It is controlled by computer with no need of die; it belongs to non-touch cutting;
2. Cutting is automatically lock stitched without dispersing;
3. It can continuously work in large batches, with fast speed, high efficiency, low production cost and good utilization rate;
4. It is equipped wind/water-cooling double temperature reducing system ensuring long time and stable operation of the equipment.
【Applicable range】 Applicable scope]: It is applicable for clothes, cases and bags, piece goods of shoes-caps factories and incision cutting of leather.
specification:
Laser type A imported radio frequency CO2 laser tube
B home-made laser tube
Laser power A standard configuration 40W
B standard configuration 75W
Work breadth 1600×1000mm
Cutting speed 0-1500mm/s
Movement system DSP professional movement control
Complete machine power 1500W
Software Guoshi photoelectrcity legitimate software DSP7.0
Overall dimension 2590×2480×1100mm
GS-5065 Crafts Gifts Machine
【Products features】
Under the control of computer, graphics can be designed at will without die-opening, it can make elaborately wrought carving and no surface penetrating carving, carving out special effect with different depth, different texture with administrative levels sense and gradual changing of color. It is equipped with dual wind /water-cooling down systems to ensure the effective functioning of equipment for a long time, continuous uninterrupted large batch operation fast, efficient, low-cost production.
【Applicable range】
Applicable materials: wood board, bamboo slip and paper, marble, rubber products, Acryl, crystal, leather, etc
Laser type Homemade sealing and dispersing type CO2 laser tube
Laser power 65W
Work breadth 500×650(mm)
Complete set of machine power 800W
Overall dimension 1360×890×1350(mm)
We can supply you with competitive price,and satisfy different demands.
Welcome friends in every industries ask for details.
guoshilaser@gmail.com
www.guoshilaser.com
ID:	23197   Click image for larger version
ID:	23198   Click image for larger version
ID:	23199   Click image for larger version
ID:	23201   Click image for larger version
Old 09-23-2006, 11:05 PM
miljnor's Avatar
S.N.A.F.U.
miljnor is on a distinguished road
what are the prices and where do the units ship from?
thanks
Michael T.
"If you don't stand for something, chances are, you'll fall for anything!"
Old 09-23-2006, 11:10 PM
can you give me your email address?and we only do FOB
Old 09-23-2006, 11:11 PM
ship from wuhan,China
Old 09-25-2006, 08:37 PM
We are going to slash 20% price from October,my boss become crazy!
Old 09-25-2006, 09:28 PM
miljnor's Avatar
S.N.A.F.U.
Since your not willing to post your prices how would someone know what 20% off is?
I will post what you sent if you can tell me if these are the normal prices or the 20% off ones?
Unless there is some overriding reasons you don't post prices on a forum?
thanks
Michael T.
Old 09-25-2006, 09:40 PM
I promise i will give you the the 20% off price.
Old 09-25-2006, 09:43 PM
miljnor's Avatar
S.N.A.F.U.
so the prices you already emailed me are the normal prices???
thanks
Michael T.
Old 09-25-2006, 09:46 PM
yes,that's the bottom price.
Old 09-25-2006, 09:48 PM
Sir,how about your budget?
Old 09-25-2006, 09:55 PM
miljnor's Avatar
S.N.A.F.U.
wee I am willing to spend in the neighborhood of 5000.00 on a laser with 1300x700 x y travel and a 350mm z travel for larger pieces.
So far redsail has the only customer service record in the U.S. do you have any referals of people that have your unit in the US?
thanks
Michael T.
Old 09-25-2006, 10:10 PM
miljnor's Avatar
S.N.A.F.U.
I just noticed your specs say 50hzt 220vac. Will these units be able to take 60Hzt 220vac?
thanks
Michael T.
