Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > Product Announcements & Manufacturer News
Product Announcements & Manufacturer News If you are a manufacturer or company with relevant news related to machining or have a new product announcement you may post it here only! (Commercial Posting Forum)
Old 12-11-2003, 12:32 PM
Rekd's Avatar
Rekd is on a distinguished road
Post Tap Drill Calculator Freeware
I've recently been running many jobs with bastard sized threads that are not found on most Tap Drill Charts. As you may know, finding the tap drill size for a #10-64 tap may be a bit of a challenge.
My solution? Create a 'chart independant' application that will calculate the required tap drill size given the tap's major dia, the desired percentage of thread, and the TPI or Pitch of the tap.
It will calculate for Inch Cut and Inch Form, as well as Metric Cut and Metric Form taps.
There are 2 different downloads; The small one is just the executable, for those that already have the VB6 Runtime libraries, and the larger one has an install program. They can be found at cadcam's FTP site under Unspecified Uploads as Tap Drill Calculator.zip and Tap Drill Calc Setup.zip.
Enjoy it and please post a comment if you try it out.
'Rekd
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
Old 12-11-2003, 12:34 PM
Rekd's Avatar
Download the exe
directly, note that you MUST have the VB6 Runtime libraries to run this. Otherwise, download the setup package from the FTP site.
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
Old 12-11-2003, 09:55 PM
mrainey is on a distinguished road
Matt,
I think it's a neat little program. As you may remember, I also wrote a thread data program (inside ME Consultant), so I find such things to be interesting.
A couple of comments:
There's room for a little "Calc" button to be a mouse-driven equivalent of the Enter key, which would feel better to me. Not a big deal, though.
Even though you don't need a tap drill chart to calculate the drill diameter for any size thread (good), your program outputs diameter data. Won't you still need a drill chart to figure out what drill to use (example M12-1.75 tap, 80% thread, requires a 10.18mm drill - off the top of your head, what available drill is nearest to that?)
Thanks for writing it and sharing it with us.
Mike
Old 12-11-2003, 11:11 PM
Rekd's Avatar
Originally posted by mrainey
Matt,
Mike
Thanks, Mike.
While a change in focus on any control will fire a calculation event, a command button for it is a good idea as well.
Also, the main reason behind this program was to eliminate having to call a rep/manufacturer or 'look it up in the bible' to find the drill size for the bastard taps. Having a reference chart for the 'closest match' is a great idea, but in many, (most?) cases it won't produce results that match a drill chart exactally, as the end result is calculated with nearly an infinate number of possible solutions for which drill sizes do not exist.
Mayhaps I'll fix myself a Rum & Coke and see if I can come up with some kind of logic or dig up a function somewhere to find the closest match, 'cuz it really would elimate another annoying step in my job...
Thanks for the tips. Great ideas!
'Rekd
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
Old 12-12-2003, 06:01 AM
A change in focus (via mouse click or Tab key) doesn't display the recalculated tap drill diameter on my system (XP Home)
Old 12-12-2003, 02:05 PM
Rekd's Avatar
Oopsie.. my bad.
Try this one. I added the Calc button and saved settings for the type of tap selected.
'Rekd
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
Old 12-12-2003, 04:44 PM
Rekd's Avatar
Someone asked if it was possible to launch this from the MasterCAM toolbar.
The answer is yes. You'll need to create a new VBScript, with this..
Code:
Const THE_FILE = "C:\TapDrillCalculator.exe"
ShellAndWait THE_FILE, False
Then save it, and modify the toolbar via Screen/Config, and point to that VB script. If you don't have 9.1, you can't do it.
'Rekd
p.s., replace the path with yours..
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
Old 12-12-2003, 05:33 PM
Looks like a winner to me.
Old 12-13-2003, 01:10 AM
motomitch1 is on a distinguished road
Where is the FTP site found?
Old 12-13-2003, 01:14 AM
CNCadmin's Avatar
Site Owner
CNCadmin has disabled reputation
HERE
Thank You,
Paul G
Site Owner-Webmaster-
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
  #11   Ban this user!
Old 01-17-2004, 03:55 PM
TAB TAB is offline
TAB is on a distinguished road
Tap calculator
I just tried the calcualtor and I have a recommendation which I think makes a software OK or awsome in my book. Make the tap diameter field able to take decimals or fractions such as 3/8 or 1/4.
Other than that I think you did a great job on the GUI and the function is good.
Old 01-24-2004, 02:20 PM
Rekd's Avatar
Re: Tap calculator
Great idea!
I've added it. I've also added a command line arg that you can use to display the metric hole size in inches instead of milimeters. Use "/in" in the shortcut to do this.
I've also shortened the time the about window stays up, and some other cosmetic changes/debugging.
I'm contemplating on some of the other suggestions, so keep an eye out.
Enjoy!
'Rekd
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
Drill Press or Mill/Drill? cbcnc Benchtop Machines 2 03-05-2005 06:03 PM
Drilling a perpendicular hole in drill rod material ngr1 General Metalwork Discussion 12 12-04-2004 10:16 AM
What size of drill bit can be used for 1/2-10 acme tap? starCNC DIY-CNC Router Table Machines 11 04-29-2004 06:36 PM
Drill & Tap Combination "DRAP" Machine1 Hard and High Speed Machining 9 02-10-2004 08:01 PM
What type of drill bits for lathe? James04 Machine Problems, Solutions , Wireless DNC, serial port 9 05-19-2003 02:37 PM
