Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > Product Announcements & Manufacturer News
Product Announcements & Manufacturer News If you are a manufacturer or company with relevant news related to machining or have a new product announcement you may post it here only! (Commercial Posting Forum)
  #25   Ban this user!
Old 01-29-2008, 06:52 PM
frog's Avatar
Dream outside the Box
frog is on a distinguished road
PDA Version ?
I love it especially with the calculate button, I was wondering would you let me recompile in with NS basic and make it work on PDA, PalmOS and WIN CE? if so let me know and I will get together with you.
Old 01-30-2008, 08:15 AM
Rekd's Avatar
Rekd is on a distinguished road
Evan, the link in post 12 is the most recent.
Tap Drill Calculator Freeware
I don't think I made an installer for it. You'll need the VB6 Runtime Library to use it.
http://www.microsoft.com/downloads/d...displaylang=en
You should download the exe and try to run it before you install the library. Meantime, I'll dig up the source and build an installer when I get time.
frog, PM me with contact info.
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
  #27   Ban this user!
Old 02-11-2008, 07:11 PM
frog's Avatar
PDA Version ?
I have been busy with school I will have a break soon, just finishing up my masters and am tired of the keyboard, if you email me the formulas that you are using I will use that or the source code what ever you are comfortable with should only take me a couple of hours, but would be sweet for everyone including myself to have in your pocket, I was also thinking about adding a speed chart for the lathe and mill to it, just an idea. if that is ok with you.
  #28   Ban this user!
Old 02-11-2008, 07:26 PM
Tinkertoy41 is on a distinguished road
Tap drill Sizes
hello:
All tap drill sizes can be found in normal calculator as follows:
Divide 1/ pitch of the tap & subtract the answer from the major diameter of the tap and go to the nearest nominal drill size.
Example: 3/8 16 tap 1/16 = .062
.375 - .062 = .312 = Tap drill size
Works for all taps English & Metric
tinkertoy 41
  #29   Ban this user!
Old 10-17-2008, 08:22 AM
mastercamguru's Avatar
mastercamguru is on a distinguished road
Cool
How about the pilot dia for roll taps:
I use:
Major dia - .0068 * % of thd * pitch = pilot dia
or for 65% thd:
Major dia - (.442*pitch) = pilot dia
Adjust for "H" level if needed for plating:
Add to Major dia
Imperial-
H3=+.0005
H4=+.001
H5=+.0015
H6=+.002
H7=+.0025
Metric-
D3=+.0005
D4=+.001
D5=+.0015
D6=+.002
D7=+.0025
Note that minor dia will increase for plating allowance this way
  #30   Ban this user!
Old 06-02-2009, 05:14 PM
frog's Avatar
I forgot about this thread, I will put something together for palm OS if anyone is still interested, I have been busy teaching engineering and IT, as well as upgrading a Boss 5, I however will make some time, I will hopefully get a beta version up soon.
  #31   Ban this user!
Old 06-09-2010, 07:48 AM
cordillera1 is on a distinguished road
Hi.
I’m trying to machine a 12mm tap x 1.75 tpi. But I having problems to find the feed and rpm for that. And of course, any help will do good for my future work on drilling and tapping. Were I find this for a cnc machine. I’m using a floating head.
thank
  #32   Ban this user!
Old 06-09-2010, 09:06 AM
eaglezsoar's Avatar
Gold Member
eaglezsoar is on a distinguished road
Unhappy
Originally Posted by CNCadmin View Post
HERE
I tried the ftp site and Firefox gives me the following error:
Warning: require_once(./../includes/config.php) [function.require-once]: failed to open stream: No such file or directory in /home/cnczone/public_html/global.php on line 30
Fatal error: require_once() [function.require]: Failed opening required './../includes/config.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/cnczone/public_html/global.php on line 30http://www.cnczone.com/forums/images/icons/icon9.gif
Regards, Carl
  #33   Ban this user!
Old 06-09-2010, 12:25 PM
skullworks is on a distinguished road
Tagged for later download attempt.
  #34   Ban this user!
Old 06-09-2010, 06:03 PM
piasdom is on a distinguished road
the speed and feed depend on your floating head.the one i have retracts faster then going in(differant gears, don't know if yours' is the same).As far as FPR goes I use the pitch of the tap. But if you are using a floating (tension/compression) holder, then you might want to feed in a bit laggin of the pitch.
1/4x32 tap = 1/32=.03125" per revolution So for a T/C holder I might feed in at .03 IPR, and feed out at .03125"
So for 1000RPM, to feed in @ 30 IPM, and feed out at 32.IPM.
(1000rpm x .03" =30 inches per minute)
Originally Posted by cordillera1 View Post
Hi.
thank
  #35   Ban this user!
Old 11-15-2011, 10:36 AM
bkelley is on a distinguished road
Nice little program,
Thank You for sharing
http://www.kelleymachining.com
  #36   Ban this user!
Old 11-15-2011, 04:37 PM
cncbpt is on a distinguished road
Program
I like this also and thank you for your time in writing it and sharing it with us.
Drill Press or Mill/Drill? cbcnc Benchtop Machines 2 03-05-2005 05:03 PM
Drilling a perpendicular hole in drill rod material ngr1 General Metalwork Discussion 12 12-04-2004 09:16 AM
What size of drill bit can be used for 1/2-10 acme tap? starCNC DIY-CNC Router Table Machines 11 04-29-2004 05:36 PM
Drill & Tap Combination "DRAP" Machine1 Hard and High Speed Machining 9 02-10-2004 07:01 PM
What type of drill bits for lathe? James04 Machine Problems, Solutions , Wireless DNC, serial port 9 05-19-2003 01:37 PM
