| Product Announcements & Manufacturer News If you are a manufacturer or company with relevant news related to machining or have a new product announcement you may post it here only! (Commercial Posting Forum) |
| Congratulation for CNC router order for agent in New Zealand completed. See the link: Woodworking CNC Router OR1530 (5'*10'Working Dimension)_CNC router_omni-cnc Here also hope could find resellers in USA, Spain, Russia. Anybody interested in reselling our CNC router, kindly let us know. omni-cnc-CNC router laser machine plasma router -OMNI Sunny |
Thank you for sharing such relevant topic with us. I really love all the great stuff you provide. Thanks again and keep it coming. Custom Logo Design |
This model is the greatest desktop cnc router for you, whatever you use at home, or school or for hobby. See below its photos, and about its parameters and other information, see the link: OR4040 Desktop CNC router_CNC router_OMNI CNC Technology Co.,Ltd. |
Today, here we show several pieces of sample photo made by our customer in New Zealand. He works on the outdoor sign by OR1325A CNC router.
__________________ Sunny Sun http://www.omni-cnc.com Email: sales@omni-cnc.com |
| OR2040 CNC router will be ready soon for Shane. By then, we will display here.
Congratulation for OR2040 CNC router completed for customer from Australia. This CNC router machine is with 4.5kw watercooling spindle, powerful driving motor, 5.5kw inverter, hiwin linear guideway and gearwheel transmission. The working table is combined with bakelite vacuum table and T-slot Alloy material. We fit 5.5kw free-oil vacuum pump for this machine. The obvious characters of this model is its powerful driving capability, 32m/min working speed; high precision: we use gearwheel on x and y axis for its speed, use ballscrew on z axis for ensuring its accuracy; there is LCD temperature monitor above spindle, rather helpful for spindle safety. The customer uses the machine mainly for ACP, wood, plastic material processing.
CNC Router: Never try to touch the bit and spindle when the machine is in the process of working on material; Do not open the control cabinet when the machine is working. About this point, OMNI has taken measures, there is safety switch with Schneider brand. When you try to open the control cabinet when the machine is working, you turn around the switch, then the switch can turn off machine automatically without damaging machine. Check the voltage and current, confirm it is right one for machine. Please fit dust collector system on the machine when you works on the material, which easily caused the powder. This is for protecting environment and operator health. Turn off power after the machine finish the work. Laser Machine: 1. The laser machine described here is a Class IV laser device and is dangerous. The laser will instantly ignite clothing, wood, paper, plastics, and many other common items and will Seriously burn Flesh, Including Eyes. Care must be taken to avoid Serious Injury and/or Blindness. Always operate this and any other high power laser in an environment free of flammable materials, children, pets, spectators, etc. Always use Infrared Eye Protection Goggles when operating this laser. Failure to due so may result in Permanent Blindness. This laser uses Lethal High Voltages. Care must be taken when working with the high voltage. Failure to do so may result in Serious Injury or Death. Find out a single stranded copper wire with more than 2mm diameter.Fix one side of it to the laser power of the laser, and the other side placed into underground. 2. Find out whether there is any bubble of the laser tube after one minute. Revolve the location of the laser tube to squeeze out the bubbles. Attention: Water inlet of the laser tube should be in the lower place, and water outlet be in the higher, so there won’t be any bubble.
Congratulations!
__________________ http://www.servotronix.com |
#10
Here, OMNI shows OR1530 CNC router from Andres in Argentina. This model's specification is as following: -1500*3000mm working dimension -4.5kw HSD air-cooling spindle -Thicken steel gantry, machine frame tubes -T-slot Aluminium alloy combined with vacuum table -High- powered driver, motor -Inverter made in Taiwan -International standard electrical parts and installation -CE certificate And the following is the feedback from Andres: Q1. What is your comment to machine working performance? A:Machine works very good. Q2. What is your comment to sales service? A:Very good. Q3. Any suggestion about our product and service? A:English version of EVERYTHING. Q4:Would you like to share some experience on the machine using or operating? A:We make a frame over the drill in order to hang the aspiration hose.
#11
Today, OMNI display several photos of processing paddle Racket by CNC Router. The paddle racket is milled at the speed of 8m/min, by 12mm ball end mill. Suggest paddle racket processing company order the special cutter with silicon carbide above part of cutter body. See attachment the paddle racket sample photos.
#12
Yesterday, OMNI made the sample test for customer in Australia. And she is very satisfied with it, also introduce her friend to check our CNC router for purchasing. See following sample photo.
| Tags |
| cnc router |
| New Machine Build- Completed the ModularCNC Router 2009v1 Free Plans | ejjenkins | DIY-CNC Router Table Machines | 5 | 03-24-2010 12:21 PM |
| 3 axis CNC Router - completed senior design project | xiaphin | DIY-CNC Router Table Machines | 3 | 03-25-2009 04:45 PM |
| partially completed CNC Router | sintratech | DIY-CNC Router Table Machines | 19 | 12-24-2006 08:38 PM |
| My completed homebuilt cnc router | cncmage | DIY-CNC Router Table Machines | 7 | 04-12-2006 12:42 PM |
| it's completed | pyroracing85 | General Metal Working Machines | 7 | 01-09-2005 05:28 PM |
