Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > Product Announcements & Manufacturer News
Product Announcements & Manufacturer News If you are a manufacturer or company with relevant news related to machining or have a new product announcement you may post it here only! (Commercial Posting Forum)
Old 06-30-2011, 01:25 AM
Hugo Shen is on a distinguished road
New machine Build
Lser engraving machine, New model
New Generation Smart, Compact & Speedy
Machine Modle: Spark Series
Laser medium Diode pumped Laser Wave Length 532 nm
Lifetime of diode 20,000 hours Max Engraving range(mm)
ellipse 170*140*100mm (directly engraving) 315x315x100mm (tiling-tech of
engraving part by part assures
Max Crystal Size(mm) 180*150*100mm 330*350*100mm
Max engraving speed(mm) 4000 points/s
New Features:
1.Smart: the whole machine is designed much smaller and lighter, more portable.
2.Speedy: with higher engraving speed to be 4000 dots/sec maximum
3. Compact: with the control PC outside the engraving machine, all the software can be installed in one PC, integrated solution for both Engraving control software and Cloudpoint processing software!!
4. Laser-pausing functionnce the engraver's door is open, the laser will pause in the middle of engraving process and it will continue once the door is closed again
New Machine Build- First Machine Build jharvey407 CNC Wood Router Project Log 120 05-12-2012 11:20 AM
Newbie- Trying to build a CNC machine markusb2 General Metal Working Machines 1 01-31-2011 06:08 PM
Possible machine build DragonsBane74 General Metal Working Machines 6 06-01-2010 07:19 AM
Newbie- Want to build my first CNC machine :D Chris85 Benchtop Machines 4 10-16-2009 12:41 PM
Need A Quote- CNC Machine Build CyborgCNC Employment Opportunity 6 08-04-2009 03:28 PM
