Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > Product Announcements & Manufacturer News
Product Announcements & Manufacturer News If you are a manufacturer or company with relevant news related to machining or have a new product announcement you may post it here only! (Commercial Posting Forum)
Old 06-10-2011, 09:49 AM
SwissType1's Avatar
SwissType1 is on a distinguished road
NEW EZR Swiss Clamp ER Collet Clamping Nuts from GenSwiss
REDUCE WORKMANS COMP CLAIMS! REDUCES MACHINE OPERATOR INJURY! WORKS WITH ANY EXISTING 'ER' STYLE TOOL HOLDER!
GenSwiss has introduced the E Z R Swiss Clamp System for fast and positive ER collet nut clamping. The new E Z R system eliminates wrench slippage and losing clamping nuts in machine sump/chip bin, keeps machine operators hands clear of sharp tooling, prevents accidental breakage of expensive ID micro-tooling and permits achieving proper torque settings. The Swiss clamp nuts replace standard Mini-Nuts and can be tightened using standard box wrenches or 3/8” drive ratchet wrench with either the E Z R wrench adaptor or the E Z R torque adaptor designed for greater clearance areas. Both adaptors engage and lock to the clamping nut with a specialized cam system on the face to deliver positive torque to the nut while eliminating slipping on the wrench and ensuring the nut does not drop into the machine sump.The new E Z R system is packaged as a kit that includes (6) E Z R Swiss clamp nuts, (1) E Z R wrench adaptor, (1) E Z R torque nut adaptor, plus spanner wrench.
CLICK HERE FOR MORE INFORMATION
Tags
collet nut, er collets, er system, tool holder
Need Help!- Building Vacuum Clamp and Mechanical Clamp Sub-Table automizer DIY-CNC Router Table Machines 11 04-27-2012 12:46 PM
Please advise: Swiss turned plastic parts. Appropriate applicaiton for swiss turn? MadMax CNC Swiss Screw Machines 15 04-14-2011 11:33 AM
Need Help!- Adding 4th axis (indexer) with clamping/unclamping capability on collet knightridar Benchtop Machines 7 09-04-2010 05:09 PM
Need Help!- Building Vacuum Clamp and Mechanical Clamp Sub-Table automizer Work Fixtures and Hold-Down Solutions 0 04-07-2008 09:05 PM
Where to buy loose 8mm T-Slot nuts and 6mm Clamping Studs Hackman Benchtop Machines 5 09-08-2007 11:57 AM
