Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > Product Announcements & Manufacturer News
Product Announcements & Manufacturer News If you are a manufacturer or company with relevant news related to machining or have a new product announcement you may post it here only! (Commercial Posting Forum)
Old 06-01-2011, 04:40 PM
Levil's Avatar
Levil is on a distinguished road
Stronger ATC spindle for Al / steel applications
Levil is proud to announce its new LV20 – ATC spindle. For those jobs that require a little more rigidity than the LV16 ATC standard spindle, the new spindle uses ISO S20T tool holders and three angular contact bearings.
This spindle is recommended for cutting Aluminum/steel parts and goes up to 17,000 RPM (computer controlled). This 2HP spindle has high torque at low and high speeds and the tool rack fits up to 11 tool holders.
You can upgrade any of our benchtop CNCs with the LV20 –ATC spindle. Check out the website www.levil.com for more info.
Ananda Leon, Levil Technology
www.levil.com
Steel mill spindle Sieg Vertical Mill, Lathe Project Log 39 07-09-2010 09:33 AM
chinese spindle on brass or steel? sethyrish Vertical Mill, Lathe Project Log 0 08-14-2009 11:21 AM
Low speed mild steel spindle needed gtrdude General Metal Working Machines 6 01-27-2009 06:20 PM
Stronger motor Kresimir Mechanical Calculations/Engineering Design 0 01-30-2007 11:59 PM
Stronger cutting bits studysession General Metalwork Discussion 15 12-07-2004 01:36 AM
