Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > Product Announcements & Manufacturer News
Product Announcements & Manufacturer News If you are a manufacturer or company with relevant news related to machining or have a new product announcement you may post it here only! (Commercial Posting Forum)
Old 05-10-2011, 03:31 AM
Hugo Shen is on a distinguished road
3D Laser Engraving Machine (ELD3000B-HS )
Technical Specification
With the technology of diode pump, air cooler, engraving speed of 3000dot/sec and max engraving size at ellipse170*140*100mm, XLELD3000B-HS can finish engraving within 1mins for a 3D model of 180,000dots, is quite suitable to run in the shopping mall or tourism place to make 3D and 2D image crystal gift on spot, receive big orders and fulfill most of the requirement from the customer. ELD3000B is also very suitable for satellite business, which means you can put several sets of the 3D Camera in different place, receive orders and send the data for engraving via Internet.
Technical Specification:
(1) Laser Medium: Diode Pumped
(2) Laser Wavelength: 532nm
(3) Lifetime of diode: 20,000 hours
(4) Input Power Standard: 220V/110V,50Hz
(5) Power consumption:<0.6~1KW
(6) Engraving Dimension:ellipse 170*140*100 (directly engraving)(Larger engraving size can be customized, like 450*350*100mm)
(7) Real average engraving speed: 2800 points/s
(8) Typical engraving time: <2mins (for 558cm crystal cube usually 350K POINTS)
(9) Resolution:800dpi
(10) Cooling: air cooler
(11) Required room temperature: 18-32℃
(12) Warranty: 1 year
(13) Mass production function: No
(14) Machine Dimension & Weight: Stand-floor: Stand-floor: L570*W780*H1100mm/110kg Desktop:L760*W560*H560mm/75kg
Place of Origin: Zhejiang in China
Brand Name: Shining 3D
FOB Price: Shanghai
Payment Terms: T/T(Bank Transfer),
Minimum Order: Set/Sets 1
Supply Ability: 10Sets/Month
Package: metal case
Delivery Time: 15 days
MOBI: 86-15925689594 TELE: 86-0571-82879352
EMAIL: hugo.shen@shining3d.com
MSN: carpenter525@hotmail.com
WEB: Shining3D, the leading supplier of 3D Digitizing solutions. Sell affordable pricing 3D Laser Engraving Machine, 3D Scanner, 3D Camera,3D Photogrammetry_Shining3D
Tags
crystal crafts, engraving machine, laser machine
sell laser engraving and cutting machine, laser marking machine lindagstar Trade Shows and Events 4 08-27-2011 05:39 AM
New Machine Build- Sell CNC router ,CNC engraving machine ,CNC laser machine kelvinguo CNC Machining Centers 0 10-07-2010 12:39 AM
Supply Laser cutting machine and Laser engraving machine sherryguo Product Announcements & Manufacturer News 5 11-27-2007 07:47 AM
