Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > Product Announcements & Manufacturer News
Product Announcements & Manufacturer News If you are a manufacturer or company with relevant news related to machining or have a new product announcement you may post it here only! (Commercial Posting Forum)
Old 04-12-2011, 04:37 PM
skelly1995 is on a distinguished road
Threading tool touch off
What is the most common practice to touch off a carbide insert threading tool for Z-axis on a CNC lathe?
Off the tool point? or off the side of the insert?
Old 04-13-2011, 09:16 AM
wendtmk's Avatar
Moderator
wendtmk is on a distinguished road
You might get a quicker and better response to your question if you ask it on one of the machining sub-forums. This forum is for "Product Announcements & Manufacturer News".
Mark
Old 04-13-2011, 11:43 AM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
I always do Z axis touch on the leading edge. If you need the point for your programming style then you can subtract 1/2 width
www.integratedmechanical.ca
Old 04-13-2011, 06:01 PM
fizzissist's Avatar
fizzissist is on a distinguished road
The edge of the tool closest to the workpiece. THAT'S what's gonna run into stuff first!
The control is going to assume you're using the edge of the tool, not the center, and if you use the center, the center is going to satisfy the -Z value. If you don't have enough relief or there's a shoulder....guess what.
It helps if you've got an optical comparator to measure both the distance from the edge of the insert to the center of the tip, but also the actual radius of the insert's tip to help dial in the X offset.
Old 04-14-2011, 09:13 AM
DANIELLE17 is on a distinguished road
I use Z axis
Need Help!- Tool Touch Off alternative? palx80 General Metalwork Discussion 13 06-20-2009 05:40 PM
Newbie- I need to know exactly how to touch off a tool boognish75 General Metalwork Discussion 5 08-24-2008 12:45 PM
K2 Tool Touch Indicator tulsah K2CNC 9 02-09-2008 10:38 PM
CNC Lathe automatic tool touch off arkum General Metalwork Discussion 0 01-07-2008 01:05 PM
Pop-up tool touch probe dmealer General Metal Working Machines 4 04-04-2005 06:47 AM
