Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > Product Announcements & Manufacturer News
Product Announcements & Manufacturer News If you are a manufacturer or company with relevant news related to machining or have a new product announcement you may post it here only! (Commercial Posting Forum)
Old 03-08-2011, 09:39 PM
kaven is on a distinguished road
The use of bridge rectifier, and the function of bridge rectifier
A bridge rectifier is a tool used to rework alternating present (AC) into direct current (DC). Moreover, a bridge rectifier is utilized in model railroads to supply the correct direct current to run the motors and other accessories. Placed within the decoder, the bridge rectifier has many functions. Let’s describe the features of a bridge rectifier:
* Present many N-channels which suggests that the facility inputs and the detrimental output of the rectifier are well connected.
* Present a multiplicity of P-channel which implies that there’s a connection between each energy inputs and the output of the rectifier.
* Facilitate third quadrant operation gate voltage management which implies that for mentioned multiplicity of stated N-channel MOSFET means and stated multiplicity of mentioned P-channel signifies that includes at the very least a component to assure fast MOSFET turn off.
With a purpose to operate the railroad, generate the minimal warmth required and get the highest present capacity, you want to configure the bridge rectifier. Via a diode, the mentioned part turns off the fast MOSFET.
There’s also the necessity for a certain part that can defend the gate terminals of the proposed multiplicity of the N-channel MOSFET means and said multiplicity of said P-channel MOSFET means from damaging voltages.
There’s additionally the necessity for inclusion of a voltage divide to determine optimum working voltages to the gate portals of stated multiplicity of said N-channel MOSFET means and mentioned multiplicity of mentioned P-channel means.
The method needs to also have a element to protect the gates of mentioned multiplicity of said N-channel MOSFET means and mentioned multiplicity of stated P-channel MOSFET means from false conduction due to some unauthentic noise impulse voltages channeled to mentioned fill bridge rectifier.
www.chinarectifiers.com
Bridge Rectifier Location cbarsh Bridgeport and Hardinge Mills 5 07-10-2008 11:08 PM
Newbie- Bridge rectifier burned danielm General Electronics Discussion 0 04-08-2008 05:45 PM
Bridge rectifier go poof blfinche Hobbycnc (Products) 7 10-18-2006 07:11 AM
bridge rectifier output najnielkp General Electronics Discussion 3 07-10-2006 11:05 AM
bridge rectifier osdhillon General Electronics Discussion 4 12-30-2005 09:24 AM
