Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > Product Announcements & Manufacturer News
Product Announcements & Manufacturer News If you are a manufacturer or company with relevant news related to machining or have a new product announcement you may post it here only! (Commercial Posting Forum)
Old 02-11-2011, 03:56 PM
Jetedge is on a distinguished road
Arrow High Flow Abrasivejet Ideal for Cutting Thicker Materials
Jet Edge’s High Flow Abrasivejet delivers up to 3.5 pounds per minute (5.95 L/min) of abrasive and up to 8.6 gallons per minute (31.15 L/min) of ultra-high pressure water for abrasive water jet cutting applications.
The High Flow Abrasivejet is ideal for cutting thick materials such as reinforced concrete or for making separation cuts in steel plates or pipes. It is capable of operating up to 55,000 psi (3800 bar) and is especially suited for use with lower-pressure, high-flow water jet pumps. It can be used with any manufacturer’s waterjet system.
Water jet systems manufacturer Jet Edge offers a wide range of water jet parts and accessories.
More Information
For more information about Jet Edge waterjets, visit www.jetedge.com or call 1-800-JET-EDGE (538-3343) or 1-763-497-8700.
Information Request Form
About Jet Edge
Established in 1984, Jet Edge is a global designer and manufacturer of waterjet systems for precision cutting, surface preparation and coating removal. Jet Edge systems are used around the world in a broad range of industries, from the world's leading airlines to automotive, aerospace, industrial manufacturers, machine and job shops. Jet Edge waterjet systems are proudly made in the U.S.A.
Jet Edge is proud to sponsor CNC Zone!
Tags
abrasivejet, water jet cutting heads, water jet parts, water jets, waterjets
Just IN- 5'x5' Water Jet Cutting Machine Ideal for Small Shops Jetedge Product Announcements & Manufacturer News 5 09-06-2011 09:15 PM
Newbie- Tips on laser cutting soft materials drmitsos Laser Engraving & Cutting Machines 4 06-12-2010 12:52 AM
Special considerations for cutting very hard materials? ksanalytical General Metal Working Machines 4 04-27-2010 08:34 AM
What to use when cutting thin materials ? twocik Benchtop Machines 5 04-07-2008 03:49 PM
High-Flow Coolant Pump motor failure; bushman's repair. Geof Haas Mills 1 12-28-2006 10:20 AM
