Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > Product Announcements & Manufacturer News
Product Announcements & Manufacturer News If you are a manufacturer or company with relevant news related to machining or have a new product announcement you may post it here only! (Commercial Posting Forum)
Old 02-10-2011, 09:39 PM
sinonsh315 is on a distinguished road
supply TF turbine oil filtration machine
NSH TF series is particularly suitable for purifying turbine lubricating oil. It also applys to treat hydraulic, coolant oil and other lubrication in which contain large of water, vapor, impurities, sludge, dielectric and colloid. It can eliminate them effectively and efficiently. TF series will result in the improvement of the properties of turbine oil, other lubrication and extend the maintenance period of turbine or other equipment which has lubrication system and keep them operate in good condition.
Edges of TF
* Perfect capacity of removing vapor, water, impurities.
* Automatic reverse-washing system filters.
* Online work.
* High performance security system.
* Easy handling and maintenance.
* Lower maintenance and replacement expenses.
* High efficiency and effectiveness.
* Small size, light weight, low noise.
* Available in mobile or stationary options.
* Various sizes and configurations (shield) available.
More information, at Sino-NSH Oil Purifier Manufacture Co. Ltd. - China
supply GER used engine oil filtration machine sinonsh315 Product Announcements & Manufacturer News 1 02-24-2011 05:36 AM
supply LV lubriction oil filtration machine sinonsh315 Product Announcements & Manufacturer News 0 02-10-2011 09:37 PM
supply VFD insulation oil filtration machine sinonsh315 Product Announcements & Manufacturer News 0 02-10-2011 09:34 PM
Sino-nsh GER Used Engine Oil Filtration machine sinonsh22 Product Announcements & Manufacturer News 0 10-26-2006 12:43 AM
China Turbine Zhongneng Turbine Oil Purification/Oil Purifier/Oil Filtration tracy127 Product Announcements & Manufacturer News 0 10-10-2006 03:19 AM
