02-04-2011, 01:43 PM
NEW IBAG ROTARY COUPLING FOR TURRET STYLE CNC LATHES | | IBAG North America has added a new Rotary Coupling that allows use of their popular IBAG Micro Line high speed spindles in turret style machines. Any IBAG Micro Line spindle can be used with the coupling, providing speeds up to 100,000 for micro milling and small diameter drilling applications.
The new Rotary Coupling provides support for all electrical and pneumatic requirements for high speed spindles. Models available for 2 or 4 spindles.
Built with IP67 rating, the Rotary Coupling uses positive air over pressure to prevent any coolant or chip contamination, and can rotate to a maximum speed of 500 RPM. The pneumatic supply within the coupling also provides air-seal to the spindles. The Rotary Coupling is mounted to the CNC lathe turret face. An anti-rotation shaft prevents the coupling from rotating as the turret spins. http://www.ibagna.com/pdfs/IBAG%20Rotary%20Coupling.pdf
Contact: Rick Testani
IBAG North America
203-407-0397 IBAG North America
