| Product Announcements & Manufacturer News If you are a manufacturer or company with relevant news related to machining or have a new product announcement you may post it here only! (Commercial Posting Forum) |
We present new 2011 v7 machine center.all syil dealer in stocking,delivery time within 3 months include china new year. Features Siemens 802s system,3 axis servo package. 5.7Inch single blue LCD display screen, showing spindle speed and direction and movement size Panel focused on manual control systems, cooling and spindle control 3 axis servo motor,siemens original spindle servo motors. 2.2KW. 800 X 250mm Size of table 10000rpm/min High Speed Precision Spindle,NSK bearing. 380V single-phase AC power supply BT30 spindle 10pcs ATC system with draw bar 2 x 120mm pre-installed high-speed cooling fan high quality casting materials, compact structure OEM PMI double nut ballscrews Hiwin precision linear guideways safety of high-quality electrical components and fast plug the integration of the base casting Automatic lubrication system pre-installed to protect the rail life Coolant/working lights pre-installed MPG handwheel controller pre-installed CE and CCC safety certification Features Overall Demensions(L x W x H)***** * - 1550mm*x*1650mm*x*2300mm Packing Demensions(L x W x H)****** - 1650mm*x*1850mm*x*2400mm Table size*********************************** * - 800mm x 250mm T Slot Demensions********************** ** - 16mm Weight******************************************- 1200~1350kg Axis travel************************************* - X axis: 400mm *************************************************** - Y axis: 240mm ********************************************** **** - Z axis: 400mm Spindle speed**************************** ** - 200~10000rpm/min Spindle drive power********** ************ *- 2.2kw Servo Spinble taper****************************** * - BT30 Input voltage***************************** ** - 220v AC 3 Phase Repeatablility**************************** ** -≤0.01mm Cutter dia*********************************** *- 4~16mm Motor torque************************* ****** - X axis motor: 8.0nm ************************************************* *- Y axis motor: 8.0nm **************************************** ********* - Z axis motor: 8.0nm
__________________ Direction,Commitment,Follow through Last edited by syil; 01-18-2011 at 08:24 PM. |
I could see 380V if it was 3 phase - But single phase ![]() Nice looking machine - how much $?
| I`m sorry,it is 220v AC 3 Phase. also,we use 802s,and v7,it is full servo machines. no any relative with stepper.. but problem it is only for 3 axis workings.... if add 4th axis ,the cost not cheap.. we are also communicate with funnc wait for them quote 4th axis controller cost..
__________________ Direction,Commitment,Follow through |
sorry,we don`t have this plan yet..
#12
| l will call syil canada to learn them advise.becuase this machine to make stocks cost big.so we need discuss to see if syil china make stocks for some important dealers around the world
| Build Thread- 2011 v7 vertical machine center | syil | Syil Products | 27 | 01-23-2011 08:30 AM |
| Problem- Vertical Machining Center MCV-720 of Dahlih not operation | bmw_m3_mine | CNC Machining Centers | 0 | 08-21-2009 04:17 AM |
| Problem- Beaver VC 15 Vertical Machining Center | MACHINEYARD | General Metal Working Machines | 0 | 11-11-2008 01:40 AM |
| Need Help!- CNC Vertical machining center | soumen | Mori lathes | 0 | 03-11-2008 09:06 AM |
| anyone knows about Mazak Vertical Center? | kamran67 | General Metal Working Machines | 3 | 07-04-2005 11:55 AM |
