Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > Product Announcements & Manufacturer News
Product Announcements & Manufacturer News If you are a manufacturer or company with relevant news related to machining or have a new product announcement you may post it here only! (Commercial Posting Forum)
Old 01-04-2011, 10:47 AM
BTA PLASMA's Avatar
BTA PLASMA is on a distinguished road
Cheap and efficient sheetmetal software now available from Plasmaland.com
We are proud supporters of 2020 software solutions and are pround to announce the releasing of Bend Tech SW. You can check it out online at Plasmaland
Plasmaland.com will ship this incredible software for $2.00.
Info
Bend-Tech SM is the hobbyist's answer to the sheet metal and plate design world. Week-end warriors no longer need to spend the big dollar or otherwise obtain the high-end solid modeling systems to design sheet metal parts. In addition, being comfortable with this software doesn't require a week-long training course or several volumes of help guides and tutorials.
Bend-Tech SM takes on an approach of design from a 2D perspective; some may refer to it as 2 1/2D. Don't be fooled, most of the work is done in 2D, however, the model that is built is full 3D. A user works on a flange or the bend zone with easy-to-find CAD tools for geometry design and manipulation.
The designers at Bend-Tech know sheet metal and understand what is needed to make quick work of designs. You will find many specific features to make your design faster, such as: path text, bridging, slots for bend relief, void slots for bend zones and manual bending, corner notches, and specific hole shapes including dimple die and ellipse; just to name a few.
Bend-Tech SM will output a DXF file to send to CAM systems for cutting or give you a one-to-one drawing on multiple sheets of paper to be used as a scaled template for fabrication. The software's flat layout will provide bend radius, angle, and direction information, as well as allow a user to dimension the tangents of each bend or the center bend line for help in bending.
If all of that wasn't enough, Bend-Tech SM has an assembly module. You can design your plates or sheet metal and assembly them together. Assembly will help you to determine if you have the look you want or make sure the parts go together correctly.
Bend-Tech SM is in a class to itself. This is the ONLY sheet metal and plate design software available on the market that is aimed primarily at the home hobbyist and weekend warrior but strong enough for job shop and production applications. A fantastic addition to our CNC plasma table line up.
Now featuring Plasmaland online
Just IN- Plasmaland.com New CNC parts or Sell your used machine BTA PLASMA Product Announcements & Manufacturer News 0 12-22-2010 12:51 PM
Best (Cheap) CNC Software to Use Stile2 JGRO Router Table Design 17 05-16-2008 03:05 PM
Cad software for sheetmetal? Klox General CAM Discussion 8 06-07-2004 01:30 AM
