Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > Product Announcements & Manufacturer News
Product Announcements & Manufacturer News If you are a manufacturer or company with relevant news related to machining or have a new product announcement you may post it here only! (Commercial Posting Forum)
Old 11-16-2010, 02:53 PM
Pacific Bearing is on a distinguished road
Arrow PBC Linear Designs Custom Hinged Mount for De-stacking System
Automation is a continually evolving way to improve efficiency, especially on the production-line. While system integration can incur high start-up costs, manufacturing lines running 24/7 save thousands in annual labor costs. This was the case for a newly designed bottle cleanser packaging and sorting conveyor using PBC Linear actuating systems in a palletizer/de-stacker. However, during the early stages of testing, the actuators were found to be loaded beyond their rating, and damaged when the system misaligned by out of position product pallets. This resulted in machine shutdowns and potential safety concerns. PBC Linear’s hardworking engineering team was brought in to assess the problem and produce a workable solution for the de-stacking mechanism.
The de-stacker is positioned at the forefront of the robotic packaging conveyor. Stacks of boxes on pallets containing empty bottles are stocked in the front, waiting to be moved further down the packaging line. As the de-stacker cycles down the pallet stack, it moves the 272 lb pallets into position to be lowered onto the conveyor and on to the next station. This mechanism required a complete system of durable and sophisticated actuators to work synchronously to complete the de-stacking tasks. To meet the challenge, the design team decided to implement PBC Linear’s versatile MT series actuators into the robotic conveyor and de-palletizer.
Installed into the system, the MT linear actuators were used to complete two different tasks: horizontally driving the bottle boxes into lowering position and vertically raising/lowering the boxes onto the transfer conveyor. These tasks needed optimal control, smooth linear motion and tolerance for high offset loads. Initially, the design team was pleased with the performance; however, they soon began to notice significant strain on the vertically mounted actuators; eventually causing the line to be shutdown. In order to find a solution, PBC Linear was asked to provide specific application assistance with the problem.
The MT series had several key advantages that made it an attractive positioning system for this application: high load tolerances facilitated by a steel-reinforced timing belt, smooth motion and velocity control supported by a ball guided rail system, and t-slots to mount vertically and horizontally. When PBC Linear investigated the actuator breakage, they realized extreme moment loads were the root cause. The load ratings of the actuators were barely exceeded during normal operation; however when the boxes were misaligned, the actuators were exposed to more than twice their rated load capacity. This excessive offset load directly lead to machine shutdown and repair, and required an immediate solution for the manufacturer to keep their lines operating.
To absorb the high moment loads, PBC Linear installed new actuators (same model and size) with dual carriages to absorb higher moments. They also designed and manufactured a special hinged mount to attach the de-stacker to the actuators in order to prevent breakage and machine shutdown. The two mounting plates were spring-loaded—allowing for the actuators to pivot when the boxes were misaligned. This prevented the actuators from being strained under high moment loads. After the actuators were equipped with the new customized mounting plate, the production line has been operating smoothly. Overall, the manufacturer was pleased with the design team’s packaging system and PBC Linear’s expert actuator support.
For more examples on how PBC Linear can be used to simplify assembly, improve performance and fully automate your material handling applications please call 1.800.729.9085, email to marketing@pbclinear.com or visit us at our LAT dedicated page at LAT.pbclinear.com.
Tags
de-palletizer, lat, linear actuator, material handling, multi-axis
Can someone help me mount the motor for this deepgroove1 system? 00nightstorm Taig Mills & Lathes 5 02-22-2009 10:52 PM
Best Pc Operating System to run CNC designs. SpeedsCustom General CNC (Mill and Lathe) Control Software (NC) 48 12-24-2007 10:23 AM
Ballscrew Flange and Linear Rod Mount? barkster Linear and Rotary Motion 0 05-03-2007 02:32 PM
Designs for 304 CNC polishing System hugabouv General Metal Working Machines 1 10-27-2005 01:54 AM
How Should I Mount Linear Encoders? lerman General Metal Working Machines 6 01-13-2005 03:50 PM
