Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > Product Announcements & Manufacturer News
Product Announcements & Manufacturer News If you are a manufacturer or company with relevant news related to machining or have a new product announcement you may post it here only! (Commercial Posting Forum)
Old 11-01-2010, 08:51 AM
leo zhu is on a distinguished road
Thumbs up Sharpecnc SXK07: strong spindle,precision rail lines,rich features.
Dear all friends,
Sharpecnc sxk07 series use precision rail lines and more strong spindle, and features more rich.
Dongguan Sharpe CNC Machine Co., Ltd. - cnc mill, cnc lathe, cnc drill
SXK07 Technical Parameter
No. Item Specification
1 Bench size,length×width (mm) 800×260
2 T-slot No./width/Pitch 5-16-50
3 max load (KG) 100
4 X travel (mm) 430
5 Y travel (mm) 270
6 Z travel (mm) 410
7 Spindle nose to table (mm) 50-460
8 Spindle axis to column 300
9 Spindle tapper Axis prick hole BT30
10 Max. Spindle speed Axis Max speed 6000/8000
11 Main motor power (KW) 2.2
12 Feed motor X torque /Stepping) (Nm) 4.3
Y torque (/Stepping) (Nm) 4.3
Z torque /Stepping) (Nm) 6
13 Fast moving speed X/Y/Z (/Stepping) 8
14 Cutting speed (Stepping) 0-4000
15 Ball screw specification X/Y/Z (diameter/pitch) 20/5
16 Linear guideway XY20mm/Z25mm
17 Driver motor Servo Motor
Stepping motor X、Y 86*65
Z 86*65
ID:	118131   Click image for larger version
ID:	118132   Click image for larger version
ID:	118133   Click image for larger version
Tags
benchtop cnc mill, benchtop mill, cnc mill, cnc milling machine
The SyiL x7 linear series,strong spindle,precision rail lines,rich features. syil Product Announcements & Manufacturer News 90 11-09-2010 03:07 AM
Need Help hooking up Viper200 Stop-Out lines to CNC4PC C1 BOB Input Lines CNC-Joe Viper Servo drives 1 08-11-2010 07:59 AM
Precision - Shaft or Rail? swisspnp Linear and Rotary Motion 3 05-13-2010 07:34 AM
Just IN- The SyiL x7 linear series,strong spindle,precision rail lines,rich features. syil Product Announcements & Manufacturer News 6 09-23-2009 05:34 AM
hidden lines only for some features in solid works viny Solidworks 5 02-14-2007 12:48 AM
