| Product Announcements & Manufacturer News If you are a manufacturer or company with relevant news related to machining or have a new product announcement you may post it here only! (Commercial Posting Forum) |
| View Poll Results: Do you like it? | |||
| Obsolutely | | 2 | 100.00% |
| Yes. I like it | | 0 | 0% |
| a little | | 0 | 0% |
| i will know more | | 0 | 0% |
| Voters: 2. You may not vote on this poll | |||
Dear all, Sharpecnc bring here his self-bonding winding machine:SWK01. Dongguan Sharpe CNC Machine Co., Ltd. - cnc mill, cnc lathe, cnc drillSHARPE SWK01 series winding machine is dedicated for all kinds of hollow coil winding. It’s high precise linear rail make sure it winding smoothly and stably, even without slot fixture . And each time due to thermal expansion or mechanical fixture flange gap caused by the changes in the position to confirm and make corrections, thus ensuring accuracy and stability around the site. SWK01 designed primarily for voice coil winding, it is installed the same number, different number routing software and the interval between the two special makeup devices, in order to achieve the basic requirement of more accurate entire column Winder Technical parameters Model swk01 Single automatic winding machine Axis (X axis) 1-axis Drive mode: 400W servo motor Stop accuracy: ± 1 ° / decomposition: 1 ° ※ rpm spindle Max. 4,500 rpm Cable (Y axis) Moving range: 80mm Drive mode: 100W servo motor Decomposition: 0.001mm Space decomposition: 0.001mm Winding width (Z axis) Drive mode: cylinder drive Adjustment method: differential regulator tube Moving range: <15mm ,the fixture can be adjusted (20mm) Decomposition: 0.001mm For coil OD: Max.ø50mm (based on your choice, can be to Ø70mm) Winding rate: Max. 20mm (Based on your choice, can be to Ø30mm) For diameter ※ ø0.015mm~ 0.6mm / flat moldings (Based on your choice, can be to Ø0.8mm) Control System Type: ARM7 processor Input: LCD touch panel Control axes 2-axis Power AC220V Power consumption Max 3.5-8A Gas source More than about 0.3MPa Machine size 960 (L)× 460 (W) × 1400 (H) mm Weight About 200kg |
| Tags |
| cnc build, cnc winding machine, coil winding, self-bonding machine, winding machine |
| CNC Coil Winding Machine | Swede | I.C. Engines | 33 | 01-28-2012 06:52 PM |
| winding machine hepl | totico | Open Source Controller Boards | 0 | 09-15-2010 01:41 PM |
| winding machine | gaitadura | Welding, Brazing, Soldering, Sealing | 0 | 02-16-2010 04:54 PM |
| Transformer Winding | sanjiv | Plasma, EDM and other similar machine Project Log | 0 | 10-24-2006 01:15 AM |
| Powermax II, which winding to get? | febisfebi | Stepper Motors and Drives | 0 | 06-03-2004 12:25 AM |
