| Product Announcements & Manufacturer News If you are a manufacturer or company with relevant news related to machining or have a new product announcement you may post it here only! (Commercial Posting Forum) |
300mm x 200mm CNC machine - £749.99 400 x 300mm CNC machine - £849.99 contact sales@premiersign.co.uk for more details. Model: BC400300 desktop CNC engraver / router Axis: 3 axis Dimensions 550x400x350mm Working area 400x300x60mm (x,y,z) Max work piece thickness <=70mm Work Table Size 450x340mm Material Composition Aluminium Alloy Sliding Unit X-axis=13mm round rail, Y-axis=16mm round rail , Z-axis=12mm round rail Transmission Unit: Special high precision 1204 double spin trapezoidal screws Stepper Motor: 3 x 57 series 2phase,1.5A new stepper motors Accuracy 0.08mm Resetting Accuracy 0.03mm Spindle 300W low noise 'refurbished' Professional model Spindle Speed 5000-9500 rpm Max Speed 4000mm/min Max Engraving Speed 2000mm/min Weight 34Kg Voltage 220V Accessories • 1 X,Y,Z control box, easy connection with spindle speed adjustment, spindle and drive on/off buttons • Cable feed system • 1 x parallel cable • 5 x engraving / milling bits • 1 x collet wrench |
No. They are different but look similar, I had a couple of machines from them and it was a mistake. The build quality was rubbish, packaging was even worse which resulted in damaged machine beds and the controllers did not work properly, I had to send the controllers back at my cost and when the 'new' ones arrived they were faulty too. Also the back of the controller was not cut properly so the 'ports' did not fit and it was virtually impossible to put the leads in. The leads were not enclosed and able to be screwed on as mine are and when all come to all, they eventually admitted that they use 'used' parts for the contollers as well so I abandoned that route. I approached a reliable company I know to build my design at my spec and that is what is for sale now. Good quality machines at a low cost! |
| Ok. Can you please tell me (or PM) me a price and some details for a 40x30 setup with larger stepper motors and a more powerful router (eg 1.2-1.5kw). Do you recommend air or water-cooled? And 2 collets that can take 2.0mm - 1/2" cutters. I am in Australia so an idea of shipping cost to postcode 3766 would be great. Thx Last edited by malcy; 09-14-2010 at 02:17 AM. Reason: spelling error |
| LOW COST BEST QUALITY LARGE RELIEF MODELS | Khalid | ArtCam Pro | 214 | 04-02-2012 06:49 AM |
| Supply cost effective high quality PCB&PCBA | fanjing322 | Product Announcements & Manufacturer News | 0 | 05-31-2010 03:31 AM |
| Need Help!- Want to buy low cost laser machines | dynamic-laser | Laser Engraving & Cutting Machines | 6 | 12-01-2009 10:14 AM |
| Just IN- Brand New High Quality - Low Cost Nested Base CNC Routing Solution | Kookaburra | Product Announcements & Manufacturer News | 0 | 09-22-2009 02:06 AM |
