| Product Announcements & Manufacturer News If you are a manufacturer or company with relevant news related to machining or have a new product announcement you may post it here only! (Commercial Posting Forum) |
![]() ![]() ![]() 8 inch Z axis , 3/4 inch aluminum , 8 inch travel .Mounting holes for for XZero router mounts and also K2 mount Also the bearing are the HGH20HA super heavy duty http://www.cnczone.com/forums/showth...863#post815863
__________________ xzero cnc .com .... xzeroautomotion@live.com http://www.facebook.com/profile.php?id=100002394631702 |
| What's the price on these?
| come with THK or Hiwin
| Z axis has no problem with one ended ballscrew at 900 IPM
| How do you keep the dust out of the ballscrew nut ? Cutting MDF would get in past the seal and stick on the grease (ballscrews need grease). Nice machining .
__________________ Manufacturer of CNC routers and Viper Servo Drives www.LarkenCNC.com and www.Viperservo.com |
Invest in a quality vacuum system that surrounds the bit. |
| #1 don't over grease ballscrews or bearing , grease every 100km of use
#10
I use a Kerk delrin nut and stainless screw , I've used ball screws in the past but they are terrible in the dust. The eventually jam up with dust in the balls especially with stepper motors.
#11
#12
Hi, I acquired a cnc frame and gantry made by Shop (S)Cam Routers Inc, and I believe Larken was the original designer. So maybe you (Larken) could help. This thread is what I have been looking for. This machine, which I have built the controller for and am trying to get set up to run flawlessly, has one of these Kerk delrin nuts on the z axis. The z axis gets stuck. Is it the nut or a motor setting? Do you know what settings should be entered in mach it uses a Vexta PK296-F4.5A stepper. Any help would be appreciated Mark |
| XZero CNC | gio666 | Xzero CNC | 2278 | 05-30-2012 11:35 PM |
| XZero Automotion eBay | gio666 | EBAY ADS | 5 | 07-08-2010 05:48 AM |
| Compare Catia and MCX2 for multi axis lathe/4 axis mill | bob1112 | General CAM Discussion | 0 | 10-10-2008 07:15 PM |
| New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter | the__extreme | CNC Wood Router Project Log | 3 | 02-26-2007 02:58 PM |
