Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > Product Announcements & Manufacturer News
Product Announcements & Manufacturer News If you are a manufacturer or company with relevant news related to machining or have a new product announcement you may post it here only! (Commercial Posting Forum)
Old 08-03-2010, 01:45 PM
Jetedge is on a distinguished road
Arrow Jet Edge Introduces 5 Axis Water Jet
Water jet manufacturer Jet Edge, Inc., is pleased to introduce the Idro line 5-axis water jet cutting machine.
For specifications, please visit http://www.jetedge.com/content.cfm?f...product_ID=139.
Capable of cutting virtually any material, the Idro line is available in three sizes, 5.5’x6.5’ nominal (1700 mm x 2000 mm), 5.5’x13’ nominal (1700 mm x 4000 mm) and 6.5’x13’ nominal (2000 mm x 4000 mm). It features the innovative IKC 5 Axis water jet cutting head, which is capable of making inclined cuts and controlling kerf to ensure optimal part quality. The IKC’s capabilities include 600º rotation, a maximum angle of +/- 60º, and dynamic precision from +/-0.2 to +/-0.5 mm/m, depending on the tilt of head.
The Idro line’s high-precision ground rack and pinion X and Y axes and ball-screw-driven 5.9” (150 mm) Z axis make it one of the most accurate waterjet systems available. It maintains a cutting tolerance +/- 0.004” (0,1 mm/m), and repeatability accuracy tolerance of +/- 0.001” (0,025 mm) and supports a contouring and rapid feed rate of 0-1575 ipm (0-40000 mm/min.)
Motion components are protected by steel covers with labyrinth lip seals to ensure lasting performance.
The Idro line is equipped with programmable contact height sensing and comes standard with one 5 axis cutting head; a second 5 axis or 3 axis cutting head can be added. Other standard features include a stainless steel tank, automatic safety guards with clear windows on front and back, and a dredge conveyor for abrasive removal. Its many options include a rotating axis for pipe cutting, fire jet etching system, a drill and twin shuttles. Free software updates are included for the life of the machine. The Idro line’s monolithic design expedites installation and makes it easy to relocate if necessary. Its rigid fixed upright bridge structure can be moved out of the way for forklift or crane loading.
About Jet Edge
Established in 1984, Jet Edge is a global designer and manufacturer of waterjet systems for precision cutting, surface preparation and coating removal. Jet Edge systems are used around the world in a broad range of industries, from the world's leading airlines to automotive, aerospace, industrial manufacturers, machine and job shops. For more information about Jet Edge, visit www.jetedge.com, e-mail sales@jetedge.com or call 1-800-JET-EDGE (538-3343).
INFORMATION REQUEST FORM
Tags
5 axis water jet, water jet, water jets, waterjet, waterjets
Just IN- New 5 Axis Water Jet Cutting Technology from Jet Edge Jetedge Product Announcements & Manufacturer News 1 09-17-2010 02:46 AM
Just IN- Waterjets Manufacturer Jet Edge Introduces 36KSI Diesel-Powered Water Jet Pump Jetedge Product Announcements & Manufacturer News 0 07-13-2009 09:48 AM
Just IN- Jet Edge Introduces 50HP 90,000 PSI Waterjet Pump Jetedge Product Announcements & Manufacturer News 0 03-19-2009 04:02 PM
Jet Edge Introduces Easy-to-Use CAD/CAM Nesting Software for Waterjet Cutting Jetedge Product Announcements & Manufacturer News 0 11-24-2008 02:31 PM
Jet Edge Introduces New Mid Rail Gantry Waterjet System Jetedge Product Announcements & Manufacturer News 0 09-23-2008 12:00 PM
