08-01-2010, 11:33 AM
Auto Cutter Calibrator TTC140~~~Get discount~~ | | New product for discount~~
See the TTC140 detalis Send your inquiry
TTC140 automatic cutter calibrator is more suitable for medium and mini machine centers, cnc drilling cutting machine, cnc engraving and milling machine and so on. SSR switch volume signal is directed supplied to cnc control system by cable most of which is connected in redial direction. Compact structure with simple connection and easy installation does not need adaptor.
1. Components: TTC140 automatic E-on knives and one piece of signal transmission cable
2. Test direction: cutter length test
3. Work method: activating.Diameter of cutter flank: 18.4mm
4. Cutter flank resetting accuracy: ±2∪m.Cutter flank max. float travel to down side:5±0.5mm
5. Cutter flank resetting spring: 2.3n-3.6n.E-on knives power: 24±50%V DC
6. Direction: one red light in the main body.Protection degree: IP68
7. Signal type and logic: common closed switch signal in general connection, signal logic could be changed
To contact mill@diylife.com.tw
www.atron.com.tw |
