Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > Product Announcements & Manufacturer News
Product Announcements & Manufacturer News If you are a manufacturer or company with relevant news related to machining or have a new product announcement you may post it here only! (Commercial Posting Forum)
Old 07-27-2010, 10:48 PM
larryy1022 is on a distinguished road
shape cutting products( cnc controller, expanding control PCB, THC)
Hi everyone,
It's quite a few days since last post. Some update on our cnc controller, THC, expanding control PCB products,
here share with you all.
Today first upload newest controller manual and expanding control PCB introduction here.
cnc controller MicroHYD-GE200-XP is mainly designed for gantry cutter.
expanding control PCB HYD-VII is mainly designed for over 2 torches multi-torch control. It supports almost all cnc controllers on market, plasma/oxy-fuel cutting.
Later will update THC and some more PCB products.
Tks
larry
HYD.CNC
stand alone torch height controller supplier
http://www.hydcnc.com/en/
Old 07-27-2010, 11:15 PM
some pics of THC took in our workshop
chc-200d is capacitive THC for oxy-fuel cutter, installed over 5000 pcs.
xpthc-100 is acr voltage THC, installed over 1500 pcs until this month.
ID:	111746   Click image for larger version
ID:	111747   Click image for larger version
Old 07-27-2010, 11:35 PM
pics took from workshop.
pics took from workshop, after the new workshop cleaned up, maybe make a vedio for demonstration.
ID:	111749   Click image for larger version
ID:	111750   Click image for larger version
Old 08-02-2010, 07:37 AM
THCs
Over 10 years practice, we developed two models of THC
For flame cutter, CHC-200D, it should be the simplest THC on operation and installation. It's almost free of service after installation. We've installed over 5000 pcs in years, especially last year just 7 pcs got pro in over 1800 pcs installation.
For plasma cutter, XPTHC-100. Stand alone type.
Control Accuracy: 1-3v.
Auto IHS ( ohmic contact and proximity switch IHS)
Set pierce delay time.
Unique design on Kerf crossing, corner turning protection (pls check details in manual).
Display Set arc and Actual arc, offers arc test, arc set such functions on operation panel, very user-friendly.
You can see from the attached wiring map, the installtion is clear demonstrated.
We designed THC for professional cutter manufacturers, but also we wish to make it a cost-effective product acceptable to most personal users.
Thus share it here, we are open to any of your comment.
Tks larry
Old 08-08-2010, 05:16 AM
HYD-VIII system
Our HYD-VIII system includes our cnc controller MicroHYD-GE200-XP and 6-torch expanding control PCB.
It can support maximum 6 plasma/flame torches.
We started to supply this system from 2008, until now, around 450 sets have been installed.
Attached is the manual of HYD-VIII system and some project pictures.
here share with guys in this zone, and we are open to any of your comment or question.
Tks
larry/ HYD.CNC
Name:	Honeybee CNC.1.jpg‎
ID:	112406   Click image for larger version
Name:	Honeybee CNC.2.jpg‎
ID:	112407   Click image for larger version
Name:	Farley retrofit.jpg‎
ID:	112408   Click image for larger version
Name:	Auto parts workshop.jpg‎
Name:	Yuexin Vessel workshop-2.jpg‎
ID:	112410   Click image for larger version
Name:	Yuexin Vessel workshop-1.jpg‎
Old 08-14-2010, 02:54 AM
new project
new project.
Abt HYD-VIII, I dont know why, but just cant upload it here, later I will try to show some pictures of the wiring work inside HYD-VIII system, and some pictures of its major parts.
ID:	112700   Click image for larger version
Old 08-14-2010, 03:37 AM
HYD-VIII system
Still cant upload the HYD-VIII manual, 2.5 M should be allowed?
I can only attach some pics of HYD-VIII system here, pls hv a look,
from the pics u can see HYD-VIII includes cnc controller, 6-torch expanding control PCB, and our HYD-made cutting operation panel, and all wiring work inside the system. You can just direclty put it on your table and run it.
you can see from the wiring work, the user's operation and future maintenance will be very simple and easy.
It is mainly used on Gantry cutter, support maximum 6 torches, plasma/flame, both are ok.
HYD-VIII after all wiring work: 4532 USD,
Servo is charged additionally, we use Mitsubishi E series servo motor, 1kw.
motor/drive: 850 USD/set.
If manual needed, it seems we can only send via email, pls contact us at
hydcnc11@126.com
Tks
larry/HYD.CNC
ID:	112703   Click image for larger version
ID:	112704   Click image for larger version
ID:	112705   Click image for larger version
Old 08-20-2010, 08:22 PM
new project
attached is our cooperation with a leading manufacturer in china
ID:	113142   Click image for larger version
Old 08-28-2010, 11:37 PM
new project
here just share some pictures of new projects, and a picture of full pack of XPTHC-100, including THC, lifter, anti-bump fixture, cables, which can be supplied separately or together, optional to customers.
Many foreign clients doult our THC not good as the intruction manual introduced. So I'm trying to collect our projects pictures to share here.
If our THC is not good, the factories making hundreds of machines would not take our THC year after year.
We just newly started to expand our products to international market on our own.
The name is new, but product's been proved.
Name:	Full pack of XPTHC-100.jpg‎
ID:	113618   Click image for larger version
ID:	113619   Click image for larger version
ID:	113620   Click image for larger version
Old 09-08-2010, 12:53 AM
cutting workpiece below2--3mm
Some clients asked for THC, as they met problem on cutting workpiece below 2-3mm.
Cutting such material, especially it's hypertherm plasma, you can see the cutting is very fast, and the steel sheet warps.
Usually we dont suggest try a cheap THC, and it's better not use THC to solve such problem.
I checked many projects pictures, finally got some pics of the solution.
It's not our product, but it's the solution, so upload it here, hope it's useful to people who are facing such problems.
larry
ID:	114175   Click image for larger version
ID:	114176   Click image for larger version
  #11   Ban this user!
Old 09-14-2010, 12:53 PM
new project
just some new projects pictures of our HYD-VIII system and THC.
ID:	114622   Click image for larger version
ID:	114623   Click image for larger version
ID:	114624   Click image for larger version
CNC shape cutting control system MicroHYD-GE200-XP larryy1022 Product Announcements & Manufacturer News 2 07-12-2010 11:28 PM
Need Help!- Expanding Fanuc Control ? newmac Fanuc 6 11-09-2009 06:33 PM
controller for world sevo products greeny AjaxCNC Control Products 1 04-11-2006 02:49 AM
controller for world servo products greeny Open Source Controller Boards 1 07-21-2005 01:51 AM
