Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > Product Announcements & Manufacturer News
Product Announcements & Manufacturer News If you are a manufacturer or company with relevant news related to machining or have a new product announcement you may post it here only! (Commercial Posting Forum)
Old 07-26-2010, 03:18 PM
Pacific Bearing is on a distinguished road
Thumbs up Self-aligning Pillow Blocks Thrive for Years in Tough Applications
For linear, rotary or oscillating motion, PBC Linear’s Simplicity® pillow blocks are an ideal solution. Simplicity pillow block housings are equipped with a patented self-aligning feature for optimum guidance, and carry the same performance advantages of the Simplicity linear plane bearing to allow for long-lasting operation in some of the most demanding environments; such as heavy industrial de-palletizers, lifting stations and milling.
Using the same proprietary Teflon liner as the Simplicity® linear bearing, Simplicity pillow blocks also self-lubricate—requiring no additional grease or oil. This allows the pillow block assemblies to be applied in clean-room reliant and food processing applications as well. Combined with plane bearing technology to disperse load and thrive in particulate-heavy environments, Simplicity pillow blocks are a versatile answer to numerous linear motion problems. Also, Simplicity pillow blocks are available in open and closed designs for Standard Inch, European Metric or Japanese Metric measurements; providing for easy existing system integration.
• ID sizes range from 1/4” to 2”
• Static Load Capacities up to 25,000 lb (111,000 N)
• Self Lubricating for oil free operation
• Standard Shell Material is Aluminum. Stainless Steel bearing shells available
• Frelon Gold bearing liner standard. Frelon J and Frelon W optional
• Seal options in nitrile rubber, urethane, and viton from ½” ID and up
• External lubrication feature is an added option
• Wide Temperature Range: -400F/+400F (-240C/+204C)
• Vibration Dampening
• Machine to tighter tolerances than industry standards
• Size Interchangeable with Industry standards
• Custom modifications available
For more information on Simplicity pillow blocks, please call 1.800.729.9085, email to marketing@pbclinear.com or visit us at our RST dedicated page at RST.pbclinear.com.
YouTube- Application Focus: Simplicity Bearings Lift Bed of Nails to check out our Pillow Block Application Focus showing Simplicity pillow blocks supplying gentle lift and tough as nails durability on a bed-of-nails lift table.
Tags
linear bearings, pbc linear, pillow block, plane bearings, self-lubricating
Use Pillow Blocks or Machine my own Housings? patriqq Linear and Rotary Motion 1 03-11-2010 05:03 PM
Seen these on TradeMe - linear bearings with pillow blocks cncmachinemad@g Australia, New Zealand Club house 2 10-22-2009 01:22 AM
PBC Linear Slides out New Stainless Steel Pillow Blocks Pacific Bearing Product Announcements & Manufacturer News 0 08-26-2009 03:50 PM
1/2" pillow blocks pbunnstf General Metalwork Discussion 2 08-11-2006 09:30 PM
Making your own pillow blocks and Rail mounts? Zephrant DIY-CNC Router Table Machines 20 05-19-2003 06:34 PM
